Hi, i am using blynk server 0.21.0 now. My hardware setup is arduino UNO USB to port COM5.
I succesfully send auth token to my gmail then copy paste into sketch then upload sketch to arduino then i create an app project and when i press play (start/run) it says device is offline. there is nothing in log exept me joining the app.
Someone already had this issue ? maybe i am skipping one important step ?
sorry i forgot to tell that also, when i run script-ser.bat it says
connect (blynk-cloud.com, 8442 ok
InOut() start
DSR is off then after a moment:
received EOF
EVENT_CLOSE
InOut() start
DSR is off Then it loop again forever
yeah it make sense i guess i skipped that part on the getting started section ? anyways now
what i did is edit bat file like you said, put my local ip adress at the set SERV_ADDR field.
Then it works but only if i have the script running while the server is started. (the script running step never ends)
when i close the script, it says device is offline on the app and i cant toggle the LED anymore.
Also, when i try to open the serial monitor of arduino, it sa1yis Port busy.
Any idea why the script doesnt end ? maybe i need to edit something else ?
From my experience (using an UNO), that is normal and good… means it is running. If the server goes off-line or you disable and reconnect your device (that is plugged into COM5) then it might start scrolling until it reconnects again (I can’t remember).
The script is a redirection… er, script… It takes the communication from the device on COM5 and redirects it thru your network to the server, and vice versa. Thus it must be running in order to do it’s thing. Just minimize the window and carry on.
Which leads to your other question…[quote=“Bob, post:6, topic:10253”]
[/quote]
Only one “purpose” at a time for the USB connection, either program your device, run your device on the network using the script, or view the serial monitor.
In order to do the first and last, you need to disable the script… OR, set up a 2nd serial port (in the case of the UNO, software serial) and with use of a TTL to USB adapter, use one port (typically the built in one) for programming / monitor use. While the 2nd (software serial - TTL to USB) for the script redirection to the network.
