Device disconnection
Hi!
I have a device disconnected from Blynk. My device Intel edison. Recommendations from underwater posts do not help. Tell me, what else can I do?
@tomyman please edit your post using the pencil icon at the bottom of the post, and add triple backticks at the beginning and end of your code so that it displays correctly.
You should also provide information about the hardware that you are using.
Correctly edited?
No.
I’ve provided you with triple backticks to copy and paste, but you’ve used a blockquite instead.
Ok
Thank you for helping with the problem of my device and your service, I’m probably going to post courses on forums
Okay, unformatted code removed.
