Delay speed
Hello
How can I make delay speed because blynk with the slider has no analog pins
I want to take the code
int sensorPin = A0;    // Analog input pin to pot
int ledPin = 7;      // PWM pin to LED
int sensorValue = 0;  // variable to store pot value
  // declare the ledPin as an OUTPUT:
  pinMode(ledPin, OUTPUT);
  // read the value from the sensor:
  sensorValue = analogRead(sensorPin);
  // turn the ledPin on
  digitalWrite(ledPin, HIGH);
  // stop the program for <sensorValue> milliseconds:
  delay(sensorValue);
  // turn the ledPin off:
  digitalWrite(ledPin, LOW);
  // stop the program for for <sensorValue> milliseconds:
  delay(sensorValue);
Slider, virtual pins and SimpleTimer.
thank you Costas
my code :slight_smile:
SoftwareSerial DebugSerial(2, 3);
int LED = 3;
int LED1 = 5;
int LED2 = 6;
int LEDspeed;
char auth[] = "8e673cec3da9d6e4ccf1";
 BLYNK_WRITE(V8){
  LEDspeed = (param.asInt());
   DebugSerial.begin(9600);
   timer.setInterval(LEDspeed, test);
  Blynk.begin(Serial, auth);
  pinMode(LED, OUTPUT);
  pinMode(LED1, OUTPUT);
  pinMode(LED2, OUTPUT);
void test() {
  digitalWrite(LED, HIGH);
   digitalWrite(LED1, LOW);
    digitalWrite(LED2, LOW);
  delay(LEDspeed);
  digitalWrite(LED, LOW);
  digitalWrite(LED1, HIGH);
  delay(LEDspeed);
  digitalWrite(LED2, HIGH);
  delay(LEDspeed);
@markop now that you have published your security token you should refresh it in the app and on the hardware.
Is your sketch working OK?
@Costas Hello
The security token is not completely missing.
The sketch works perfectly
