Today, all decimals stopped showing up in the Mobile dashboard.
I see the integer part and 3 dots on all numbers. The unit has disappeared too.
I haven’t touched anything in the Template or in the sketch.
I can see them normally in the Web dashboard.
I’ve also noticed some minor changes in the font used in the Mobile dashboard.
Any hint on what could be the cause?
Thank you very much
Best regards, Horacio
I mean, decimals of Value Display widgets.
App version?
Hi Pete,
1.5.0 (67) as “About” in the App indicates.
Horacio
Looks like you need to make the font size smaller. three dots is an indication that whole text has not fit in the available space
Thank you very much for the advise. And specially for the speed of your answers!
That solved the problem.
Kindest regards
