Hello everyone ,
I’m new around here and with blynk.
I’m using an Arduino UNO and ESP8266.
I am using the latest Android and version of app.
ESP is connected to 3.3V and with level shifter for RX /TX .
CH_PD is connected to 3.3V via a resistor.
The Esp has v0.9.2.2 AT Firmware installed .
I have a issues with receiving the data to blynk app with delay.
if i set 5 s or 10 s for timer i get the data updated on app after 20-40 seconds.
and also I don’t know why it does not send the correct values.
The code is tested and is working good and the values are correct from sensors. ( via Serial monitor).
Also i had to comment out all the serial. Print because they are not working and is making the esp disconnect and reconnect non-stop.
Any suggestions or directions would be appreciated.
#include <ESP8266_Lib.h>
char auth[] = "XXXXXXX";
char ssid[] = "XXXXXXX";
char pass[] = "XXXXXX";
SoftwareSerial EspSerial(10, 11); // RX, TX
#define ESP8266_BAUD 9600
ESP8266 wifi(&EspSerial);
/* 0- General */
int decimalPrecision = 2; // decimal places for all values shown in LED Display & Serial Monitor
/* 1- AC Voltage Measurement */
int VoltageAnalogInputPin = A2; // Which pin to measure voltage Value
float voltageSampleRead = 0; /* to read the value of a sample*/
float voltageLastSample = 0; /* to count time for each sample. Technically 1 milli second 1 sample is taken */
float voltageSampleSum = 0; /* accumulation of sample readings */
float voltageSampleCount = 0; /* to count number of sample. */
float voltageMean ; /* to calculate the average value from all samples*/
float RMSVoltageMean ; /* square roof of voltageMean*/
/*1.1 Offset AC Voltage */
int voltageOffsetRead = 0; /* to change the mode for offset */
float voltageOffset1 = 0; // to Offset deviation and accuracy. Offset any fake current when no current operates.
// Offset will automatically callibrate when SELECT Button on the LCD Display Shield is pressed.
// If you do not have LCD Display Shield, look into serial monitor to add or minus the value manually and key in here.
float voltageOffset2 = 0; // to offset value due to calculation error from squared and square root.
float voltageSampleSumOffset =0; /* accumulation of sample readings for offset */
float offsetVoltageMean = 0; /* to calculate the average value from all samples for offset, in analog values*/
float voltageOffsetLastSample = 0; /* to count time for each sample for offset purpose. */
float voltageOffsetSampleCount = 0; /* to count number of sample for offset. */
/* 2- AC Current Measurement */
int CurrentAnalogInputPin = A0; // Which pin to measure Current Value
float mVperAmpValue = 33.33; // If using ACS712 current module : for 5A module key in 185, for 20A module key in 100, for 30A module key in 66
// If using "Hall-Effect" Current Transformer, key in value using this formula: mVperAmp = maximum voltage range (in milli volt) / current rating of CT
/* For example, a 20A Hall-Effect Current Transformer rated at 20A, 2.5V +/- 0.625V, mVperAmp will be 625 mV / 20A = 31.25mV/A */
float currentSampleRead = 0; /* to read the value of a sample*/
float currentLastSample = 0; /* to count time for each sample. Technically 1 milli second 1 sample is taken */
float currentSampleSum = 0; /* accumulation of sample readings */
float currentSampleCount = 0; /* to count number of sample. */
float currentMean ; /* to calculate the average value from all samples*/
float RMSCurrentMean =0 ; /* square roof of currentMean*/
float FinalRMSCurrent ; /* the final RMS current reading*/
/*2.1 Offset AC Current */
int currentOffsetRead = 0; /* to change the mode for offset */
float currentOffset1 = 0; // to Offset deviation and accuracy. Offset any fake current when no current operates.
// 26 means add 26 to all analog value measured
float currentOffset2 = 0; // to offset value due to calculation error from squared and square root.
float currentSampleSumOffset = 0; /* accumulation of sample readings for offset */
float offsetCurrentMean = 0; /* to calculate the average value from all samples for offset, in analog values*/
float currentOffsetLastSample = 0; /* to count time for each sample for offset purpose. */
float currentOffsetSampleCount = 0; /* to count number of sample for offset. */
/* 3- AC Power Measurement */
float sampleCurrent1 ; /* use to calculate current*/
float sampleCurrent2 ; /* use to calculate current*/
float sampleCurrent3 ; /* use to calculate current*/
float apparentPower; /* the apparent power reading (VA) */
float realPower = 0; /* the real power reading (W) */
float powerSampleRead = 0; /* to read the current X voltage value of a sample*/
float powerLastSample = 0; /* to count time for each sample. Technically 1 milli second 1 sample is taken */
float powerSampleCount = 0; /* to count number of sample. */
float powerSampleSum = 0; /* accumulation of sample readings */
float powerFactor = 0; /* to display power factor value*/
/*3.1 Offset AC Power */
int powerOffsetRead = 0; /* to change the mode for offset */
float powerOffset = 0; // to Offset deviation and accuracy. Offset any fake current when no current operates.
float powerOffsetLastSample = 0; /* to count time for each sample for offset purpose. */
float powerOffsetSampleCount = 0; /* to count number of sample for offset. */
void Event()
Blynk.virtualWrite(V1,RMSVoltageMean);
Blynk.virtualWrite(V2,FinalRMSCurrent);
Blynk.virtualWrite(V3,powerFactor);
Blynk.virtualWrite(V4,realPower);
Blynk.virtualWrite(V5,apparentPower);
void timp ()
Blynk.virtualWrite(V0,millis()/1000);
void setup() /*codes to run once */
// Set ESP8266 baud rate
//Blynk.begin(auth, wifi, ssid, pass, "blynk-cloud.com", 80);
//Blynk.begin(auth, wifi, ssid, pass, IPAddress(192,168,1,100), 8080);
timer.setInterval(20000L, Event);
timer.setInterval(1000L, timp);
void loop() /*codes to run again and again */
/* 0- General */
/* 0.1- Button Function */
int buttonRead;
buttonRead = analogRead (5);
if (buttonRead > 800)
currentOffsetRead = 1; // to activate offset for current
voltageOffsetRead = 1; // to activate offset for voltage
powerOffsetRead = 1; // to activate offset for power
/* set display words starting at upper left corner*/
// Serial.print ("INITIALIZING..... ");
/* set display words starting at lower left corner*/
// Serial.print ("WAIT 5 SEC ..... ");
if(millis() >= voltageLastSample + 1 ) /* every 1 milli second taking 1 reading */
voltageSampleRead = 2*(analogRead(VoltageAnalogInputPin)- 512) + voltageOffset1; /* read the sample value */
voltageSampleSumOffset = voltageSampleSumOffset + voltageSampleRead; /* values accumulate for offset purpose every milli second */
voltageSampleSum = voltageSampleSum + sq(voltageSampleRead) ; /* accumulate value with older sample readings*/
voltageSampleCount = voltageSampleCount + 1; /* to move on to the next following count */
voltageLastSample = millis() ; /* to reset the time again so that next cycle can start again*/
if(voltageSampleCount == 1000) /* after 1000 count or 1000 milli seconds (1 second), do the calculation and display value*/
offsetVoltageMean = voltageSampleSumOffset/voltageSampleCount; /* average the offset reading*/
voltageMean = voltageSampleSum/voltageSampleCount; /* calculate average value of all sample readings taken*/
RMSVoltageMean = sqrt(voltageMean)+ voltageOffset2; /* square root of the average value*/
Serial.print(" The Voltage RMS value is: ");
Serial.print(RMSVoltageMean,decimalPrecision);
Serial.println(" V ");
voltageSampleSum =0; /* to reset accumulate sample values for the next cycle */
voltageSampleCount=0; /* to reset number of sample for the next cycle */
voltageSampleSumOffset=0;
/* 1.1 - Offset AC Voltage */
if(voltageOffsetRead == 1) /* Run this code when button SELECT is pressed */
voltageOffset1 = 0;
if(millis()>= voltageOffsetLastSample + 1) /* keep countng time for offset1*/
voltageOffsetSampleCount = voltageOffsetSampleCount + 1; /* 1 milli second add 1 count*/
voltageOffsetLastSample = millis(); /* to reset the time again so that next cycle can start again*/
if(voltageOffsetSampleCount == 2000) /* after 2 seconds, run this codes. */
voltageOffset1 = -1*(offsetVoltageMean); /* set the offset values */
voltageOffsetRead = 2; /* go for second offset Settings */
voltageOffsetSampleCount = 0; /* to reset the time again so that next cycle can start again */
if(voltageOffsetRead == 2) /* Run this code after first offset done */
voltageOffset2 = 0; /* set back currentOffset2 as default*/
if(millis()>= voltageOffsetLastSample + 1) /* keep countng time for offset2*/
voltageOffset2 = - RMSVoltageMean; /* set the offset values */
voltageOffsetRead = 0; /* change the offset mode to original, wait until the button is pressed again */
if(millis() >= currentLastSample + 1) /* every 1 milli second taking 1 reading */
currentSampleRead = analogRead(CurrentAnalogInputPin)-512 + currentOffset1; /* read the sample value */
currentSampleSumOffset = currentSampleSumOffset + currentSampleRead; /* accumulate offset value */
currentSampleSum = currentSampleSum + sq(currentSampleRead) ; /* accumulate value with older sample readings*/
currentSampleCount = currentSampleCount + 1; /* to move on to the next following count */
currentLastSample = millis(); /* to reset the time again so that next cycle can start again*/
if(currentSampleCount == 1000) /* after 1000 count or 1000 milli seconds (1 second), do the calculation and display value*/
offsetCurrentMean = currentSampleSumOffset/currentSampleCount; /* average offset value*/
currentMean = currentSampleSum/currentSampleCount; /* calculate average value of all sample readings taken*/
RMSCurrentMean = sqrt(currentMean)+currentOffset2 ; /* square root of the average value*/
FinalRMSCurrent = (((RMSCurrentMean /1024) *5000)/ mVperAmpValue ); /* calculate the final RMS current*/
// Serial.print(" The Current RMS value is: ");
// Serial.print(FinalRMSCurrent,decimalPrecision);
// Serial.println(" A ");
currentSampleSum =0; /* to reset accumulate sample values for the next cycle */
currentSampleCount=0; /* to reset number of sample for the next cycle */
currentSampleSumOffset=0; /* to reset accumulate offset value for the next cycle*/
/* 2.1 - Offset AC Current */
if(currentOffsetRead == 1) /* Run this code when button SELECT is pressed */
currentOffset1 = 0; /* set currentOffset back to default value*/
if(millis()>= currentOffsetLastSample + 1) /* keep countng time for offset1*/
currentOffsetSampleCount = currentOffsetSampleCount + 1;
currentOffsetLastSample = millis();
if(currentOffsetSampleCount == 2000) /* after 2 seconds, run this codes. */
currentOffset1 = - offsetCurrentMean; /* set the offset values */
currentOffsetRead = 2; /* go for second offset Settings */
currentOffsetSampleCount = 0; /* to reset the time again so that next cycle can start again */
if(currentOffsetRead == 2) /* Run this code after first offset done */
currentOffset2 = 0; /* set back currentOffset2 as default*/
if(millis()>= currentOffsetLastSample + 1) /* keep countng time for offset2*/
currentOffset2 = - RMSCurrentMean; /* set the offset values */
currentOffsetRead = 0; /* change the offset mode to original, wait until the button is pressed again */
/* 3- AC Power with Direction */
if(millis() >= powerLastSample + 1) /* every 1 milli second taking 1 reading */
sampleCurrent1 = analogRead(CurrentAnalogInputPin)-512+ currentOffset1;
sampleCurrent2 = (sampleCurrent1/1024)*5000;
sampleCurrent3 = sampleCurrent2/mVperAmpValue;
voltageSampleRead = 2*(analogRead(VoltageAnalogInputPin)- 512)+ voltageOffset1 ;
powerSampleRead = voltageSampleRead * sampleCurrent3 ; /* real power sample value */
powerSampleSum = powerSampleSum + powerSampleRead ; /* accumulate value with older sample readings*/
powerSampleCount = powerSampleCount + 1; /* to move on to the next following count */
powerLastSample = millis(); /* to reset the time again so that next cycle can start again*/
if(powerSampleCount == 1000) /* after 1000 count or 1000 milli seconds (1 second), do the calculation and display value*/
realPower = ((powerSampleSum/powerSampleCount)+ powerOffset) ; /* calculate average value of all sample readings */
// Serial.print(" The Real Power (W) is: ");
// Serial.print(realPower);
// Serial.println(" W ");
apparentPower= FinalRMSCurrent*RMSVoltageMean; /*Apparent power do not need to recount as RMS current and RMS voltage values available*/
// Serial.print(" The Apparent Power (VA) is: ");
// Serial.print(apparentPower,decimalPrecision);
// Serial.println(" VA ");
powerFactor = realPower/apparentPower;
if(powerFactor >1 || powerFactor<0)
powerFactor = 0;
// Serial.print(" The Power Factor is: ");
// Serial.println(powerFactor,decimalPrecision);
powerSampleSum =0; /* to reset accumulate sample values for the next cycle */
powerSampleCount=0; /* to reset number of sample for the next cycle */
/* 3.1 - Offset AC Power */
if(powerOffsetRead == 1) /* Run this code after first offset done */
powerOffset = 0; /* set back currentOffset2 as default*/
if(millis()>= powerOffsetLastSample + 1) /* keep countng time for offset2*/
powerOffsetSampleCount = powerOffsetSampleCount + 1;
powerOffsetLastSample = millis();
if(powerOffsetSampleCount == 5000) /* after 5 seconds, run this codes. */
powerOffset = -realPower;
powerOffsetRead = 0; /* change the offset mode to original, wait until the button is pressed again */
powerOffsetSampleCount = 0; /* to reset the time again so that next cycle can start again */
