Dashboard connection
Problem this morning to connect to blynk.cloud from my office
:thinking:
2021-06-22_115016
same to connect with android App
2021-06-22_122610
connected on ESP32 :
2:08:29.127 ->    / _ )/ /_ _____  / /__
12:08:29.127 ->   / _  / / // / _ \/  '_/
12:08:29.127 ->  /____/_/\_, /_//_/_/\_\
12:08:29.127 ->         /___/ v1.0.0 on ESP32
12:08:29.127 ->
12:08:29.127 -> [2651] Connecting to blynk.cloud:80
12:08:29.195 -> [2730] Redirecting to fra1.blynk.cloud:80
12:08:29.195 -> [2732] Connecting to fra1.blynk.cloud:80
12:08:29.298 -> [2823] Ready (ping: 36ms).
12:08:29.469 -> [2991] Time sync: OK
12:08:30.801 -> Current time: 12:8:31 22 6 2021
12:08:31.997 -> Current time: 12:8:32 22 6 2021
12:08:32.816 -> Current time: 12:8:33 22 6 2021
12:08:33.977 -> Current time: 12:8:34 22 6 2021
Ping is ok
Envoi d’une requête 'ping' sur blynk.cloud [159.65.55.83] avec 32 octets de données :
RĂ©ponse de 159.65.55.83 : octets=32 temps=24 ms TTL=46
RĂ©ponse de 159.65.55.83 : octets=32 temps=30 ms TTL=46
RĂ©ponse de 159.65.55.83 : octets=32 temps=23 ms TTL=46
When I got connection the clock is frozen
2021-06-22_122106
I have to refresh manually
2021-06-22_123624
What does ping fra1.blynk.cloud shows?
Do you have some kind of proxy or VPN in your office network? I see that hardware doesn’t use ssl, while app and web - does. This is usually means that you have some proxy between.
Could you please send me logs when you see this problem again? Also, checking the browser console would have as well.
No VPN at office, but ISP router firewall, I can take control of it if needed.
In fact, I can connect my phone to blynk cloud and I can see all widgets running (wifi network )
NoxPlayer doesn’t want to connect
Dashboard connected after 60 sec but all widgets are frozen
My browser is firefox 89, tried with Edge too, no success
From where can I export logs ?
Envoi d’une requête 'ping' sur fra1.blynk.cloud [46.101.217.214] avec 32 octets de données :
RĂ©ponse de 46.101.217.214 : octets=32 temps=33 ms TTL=47
RĂ©ponse de 46.101.217.214 : octets=32 temps=32 ms TTL=47
RĂ©ponse de 46.101.217.214 : octets=32 temps=35 ms TTL=47
2021-06-22_155331
It could be another issue, not related to the network. Can you check the browser “developer console”?
Thanks, I will do that tomorrow at my office.
@Dmitriy
Since this morning , everything comes back in order without doing anything ! :stuck_out_tongue_winking_eye:
No changes on our side. When you see this again - please check the browser console, most likely it’s some kind of network error, it would be nice to know what exactly.
