I use a 4 channel relay, why when nodemcu is connected online to wifi one of the led relays connected to D1 is always on?
even though the D1 button in the Blynk application is off.
Thankyou for the response…!
#include <DHT.h>
char auth[] = "xxxx";
char ssid[] = "PULPSTONE";
char pass[] = "internet";
bool pirEnabled = false;
BLYNK_WRITE(V1){
int control4DigitalPins = param.asInt();
if(control4DigitalPins == 1){
digitalWrite(D1, HIGH);
digitalWrite(D2, HIGH);
digitalWrite(D3, HIGH);
digitalWrite(D7, HIGH);
else{
digitalWrite(D1, LOW);
digitalWrite(D2, LOW);
digitalWrite(D3, LOW);
digitalWrite(D7, LOW);
BLYNK_WRITE(V3){ // button in switch mode
if(param.asInt()){
pirEnabled = true;
else{
pirEnabled = false;
#define DHTPIN 2 // What digital pin we're connected to
#define ledPower 16
//#define DHTTYPE DHT22 // DHT 22, AM2302, AM2321
//#define DHTTYPE DHT21 // DHT 21, AM2301
DHT dht(DHTPIN, DHTTYPE);
void sendSensor()
int h = dht.readHumidity();
int t = dht.readTemperature(); // or dht.readTemperature(true) for Fahrenheit
if (isnan(h) || isnan(t)) {
return;
int p=digitalRead(14);
Blynk.virtualWrite(V5, h);
Blynk.virtualWrite(V6, t);
if((p==HIGH) && (pirEnabled == true)){
Blynk.notify("Gerakan terdeteksi");
pinMode (ledPower,OUTPUT);
digitalWrite (ledPower, HIGH);
pinMode(14,INPUT);
dht.begin();
timer.setInterval(10000L, sendWifi);
void sendWifi()
Blynk.virtualWrite(V2, map(WiFi.RSSI(), -105, -40, 0, 100) );
