Create multiple page dashboards
The idea here is that you may want to use the 1st dashboard to setup your project, then a second dashboard to operate it and 3rd to perform a special or auxiliary function. You would be able to switch between them depending on where you are in your process
Thanks for the idea!
We were considering it at the beginning, but from UI perspective - it will conflict with other widgets’ interaction. So we won’t implement it in nearest future.
