You CANNOT use GPIO 10 when using the Ethernet Shield.
It looks like 11, 12, 13, 50, 51, 52 and 53 may have restrictions as well.
I would re-wire your hardware and avoid using these pins.
Yeah, i changed the pin but simply i didn’t post another time the sketch.
Even with the 12, 12, 10 and 4 free it doesn’t connect.
This is the actual sketch, i also added a Led Matrix 8x8 to make a smile
LedControl lc = LedControl(22, 24, 23, 1); // Pins: DIN,CLK,CS, # of Display connected
#include <LiquidCrystal.h> // Includi libreria Display LCD
LiquidCrystal lcd(2, 3, 30, 5, 6, 7); // Dichiara Pin Display LCD
#include <Ethernet.h>
char auth[] = "a21d67306eb74d609d85d130b284e443";
#define W5100_CS 10
#define SDCARD_CS 4
int livelloacqua = 0;
int umiditaterra = 0;
int notifica = false;
#define LEDV1 8
#define LEDV2 9
#define LEDR1 11
#define LEDR2 32
int ReCnctFlag; // Reconnection Flag
int ReCnctCount = 0; // Reconnection counter
unsigned long delayTime = 200; // Delay between Frames
// Put values in arrays
byte felice[] =
B00111100,
B01000010,
B10100101,
B10000001,
B10100101,
B10011001,
B01000010,
B00111100
byte triste[] =
B00111100,
B01000010,
B10100101,
B10000001,
B10011001,
B10100101,
B01000010,
B00111100
pinMode(SDCARD_CS, OUTPUT);
digitalWrite(SDCARD_CS, HIGH); // Deselect the SD card
Blynk.config(auth);
Blynk.connect();
lcd.begin(16, 2);
pinMode(8, OUTPUT);
pinMode(9, OUTPUT);
pinMode(11, OUTPUT);
pinMode(32, OUTPUT);
lcd.clear();
lc.shutdown(0, false); // Wake up displays
lc.shutdown(1, false);
lc.setIntensity(0, 5); // Set intensity levels
lc.setIntensity(1, 5);
lc.clearDisplay(0); // Clear Displays
lc.clearDisplay(1);
timer.setInterval(400L, programma); // run programma every 1 second
BLYNK_CONNECTED() {
Serial.println("Cconnected");
ReCnctCount = 0;
// Take values in Arrays and Display them
void sfelice()
for (int i = 0; i < 8; i++)
lc.setRow(0, i, felice[i]);
void striste()
lc.setRow(0, i, triste[i]);
void programma() {
livelloacqua = analogRead(A0);
Blynk.virtualWrite(V1, livelloacqua);
umiditaterra = analogRead(A1);
Blynk.virtualWrite(V2, umiditaterra);
lcd.setCursor(0, 0);
if ((livelloacqua < 160 && !notifica)) {
lcd.print("Riempire acqua ");
Blynk.notify("L'acqua è in esaurimento! Devi riempirla!");
notifica = true;
if ((livelloacqua >= 130) && (notifica == true)) {
lcd.print("Acqua OK ");
notifica = false;
if (umiditaterra > 500) {
lcd.setCursor(0, 1);
lcd.print("Annaffiare ");
digitalWrite(8, LOW);
digitalWrite(9, LOW);
digitalWrite(11, HIGH);
digitalWrite(32, HIGH);
striste();
delay(100);
if (umiditaterra < 500) {
lcd.print("Pianta OKAY ");
digitalWrite(8, HIGH);
digitalWrite(9, HIGH);
digitalWrite(11, LOW);
digitalWrite(32, LOW);
sfelice();
delay(100);
if (Blynk.connected()) { // If connected run as normal
} else if (ReCnctFlag == 0) { // If NOT connected and not already trying to reconnect, set timer to try to reconnect in 30 seconds
ReCnctFlag = 1; // Set reconnection Flag
Serial.println("Starting reconnection timer in 30 seconds...");
timer.setTimeout(30000L, []() { // Lambda Reconnection Timer Function
ReCnctFlag = 0; // Reset reconnection Flag
ReCnctCount++; // Increment reconnection Counter
Serial.print("Attempting reconnection #");
Serial.println(ReCnctCount);
Blynk.connect(); // Try to reconnect to the server
}); // END Timer Function
I would be going the other direction if I were you. That is, take stuff out until it works, then start adding stuff back in. You need to determine what is causing the connection issue first.
Try starting with a very basic sketch that will connect and slowly add the other stuff in, checking each time you add something.
Ok so you don’t think that the problem is the lines for the reconnection? if i delete that part of the sketch he circuit doesn’t work offline but perfectly with the ethernet
OK, then that may be the issue.
@Gunner, do you have any insight on this as the re-connection portion was taken from your examples. Does it only work for WiFi, or are there additional lines of cede needed for Ethernet?
Post the code you use without the re-connection stuff.
Tested and, just with ethernet, everything’s good:
#define W5100_CS 10
#define SDCARD_CS 4
#define LEDV1 8
#define LEDV2 9
#define LEDR1 11
#define LEDR2 32
byte felice[] =
B00111100,
B01000010,
B10100101,
B10000001,
B10100101,
B10011001,
B01000010,
B00111100
byte triste[] =
B00111100,
B01000010,
B10100101,
B10000001,
B10011001,
B10100101,
B01000010,
B00111100
Blynk.begin(auth);
//Blynk.begin(auth, "blynk-cloud.com", 80);
//Blynk.begin(auth, IPAddress(192,168,1,100), 8080);
// For more options, see Boards_Ethernet/Arduino_Ethernet_Manual example
lcd.begin(16, 2);
pinMode(8, OUTPUT);
pinMode(9, OUTPUT);
lcd.clear();
lc.clearDisplay(1);
void sfelice()
void striste()
void programma() {
notifica = true;
notifica = false;
striste();
delay(100);
sfelice();
delay(100);
In setup(), try changing
Blynk.begin(auth);
to
Blynk.config(auth);
Blynk.connect();
I am curious to see if this still works. To be honest, I am not certain on these topics and it may require a bit of trial and error to get it going
Nope, adding that line nothing works, offline or online
Ok after more digging. I think I found something. You need to add the mac address.
Add this near you variable declarations, but use the mac address for your Ethernet Shield
byte mac[] = {
0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED
And change/add this in the setup()
Ethernet.begin(mac);//add this
Blynk.config(auth, "blynk-cloud.com", 8080);
Blynk.connect();
Ok so, i upload the sketch with the reconnection-thing adding this 3 lines and the mac address. Now the circuit go online just for a few seconds, send the notification and then disconnect and re-connect again all by itself with the ethernet connected. BUT all the circuit, without the ethernet, doesn’t work
this is the sketch:
#define W5100_CS 10
#define SDCARD_CS 4
#define LEDV1 8
#define LEDV2 9
#define LEDR1 11
#define LEDR2 32
byte mac[] = {
0xC8, 0x60, 0x00, 0x49, 0xA2, 0xEE
byte felice[] =
B00111100,
B01000010,
B10100101,
B10000001,
B10100101,
B10011001,
B01000010,
B00111100
byte triste[] =
B00111100,
B01000010,
B10100101,
B10000001,
B10011001,
B10100101,
B01000010,
B00111100
Blynk.connect();
lcd.begin(16, 2);
pinMode(8, OUTPUT);
pinMode(9, OUTPUT);
lcd.clear();
lc.clearDisplay(1);
BLYNK_CONNECTED() {
ReCnctCount = 0;
void sfelice()
void striste()
void programma() {
notifica = true;
notifica = false;
striste();
delay(100);
sfelice();
delay(100);
Does it trigger the re-connection stuff? That is, do the serial prints show up for the re-connection on the monitor?
Also, what does the monitor show when it disconnects? Screenshot?
What about if you leave the re-connection stuff out of loop(). That is just have timer.run and blynk.run in the loop().
Where should i put that lines? In the setup?
What if to do the reconnection i use an interrupt instead of the if and the flag?
Don’t think that is how it works. The IF checks if it is connected then takes appropriate action.
Everything the same as the last code you posted, except…
With the Ethernet cable plugged in.
I know it wont work with the Ethernet cable unplugged, just want to see if it stays connected
Yes, exactly like you said. Unplugged nothing but now the connection doesn’t drop like before and online everything fine
Try this, and let me know what the serial prints show.
Nope, nothing. I bought an ESP8266-01 model (https://www.amazon.it/SunFounder-ESP8266-Wireless-Transceiver-Mega2560/dp/B00U293Y5M) this guy and now i wan to try with this type of connection instead of the ethernet and with the first @Gunner code to see if this can be the solution. How can i do? I’m trying to blink a led with an arduino UNO but i’m sure that i’m making some mistakes. Any help?
with this it doesn’t work offline…
EDIT: just my mistake, IT WORKS !!! I have to wait like 2 minutes before the “offline-start” but it works perfectly
How are you testing the offline functionality?
If you’re powering-off your router then it won’t work, no matter what code you’re using.
