Counter with blynk
Hi.
I have a simple application at standalone esp8266 with one digital button GPIO0. I need to make a couter and should now, how many times the users clicked them. I don’t know how to make the “if part”. Please advice.
char auth[] = “”;
// Set password to “” for open networks.
char ssid[] = “”;
char pass[] = “”;
int counter = 0; // Set counter to 0
int button =0; // Set button to GPIO0
if …
counter++;
Blynk.virtualWrite(V5, counter);
// This command writes Arduino’s uptime in seconds to Virtual Pin (5)
Look for examples that talk about debouncing,
use analogRead(button); to get the button value - you will find such statements in the debounce examples.
call such code from your loop()
once debounced your code:
counter++;
should be fine
Thank’s for your message, the button will be virtual at blynk, not physical, how should I change the code?
In that case, use a virtual pin rather than a digital pin.
