That’s amazing… pretty much what I am attempting to do!
Hi Trev,
I recently discovered a bug on the ‘node-red-contrib-blynk-ws’ library, indeed the CONNECT_REDIRECT command is a valid command not a SERVER_EXCEPTION. Apparently the server is asking us to change the address / port where to connect.
It would be interesting to do further tests … do you still have the aws server? Would you do some tests with an updated library if I send it to you?
@Dmytro Could you explain how a client should behave when the CONNECT_REDIRECT command is received? could you give me an example of such logs? it is not easy to recreate this problem.
regards
Gabriele
Hardware sends login command. In case token for login command is not found on the server that is resolved via geo dns request (by hostname) than server returns CONNECT_REDIRECT command in format serverIP:port. Where server:port is server which hosts your user data.
As workaround you may directly connect to the server that returned in CONNECT_REDIRECT instead of “blynk-cloud.com” host.
node-red-contrib-blynk-ws seems to be outdated and doesn’t support CONNECT_REDIRECT
Yes, I still have my AWS box running. it’s running my MQTT mosquito service. Which works great.
I have just got back from the pub so typing with one eye open at the moment.
Would be more than happy to try and help with AWS.
Where should I start?
@Dmytro Yes geoDNS! Thank you!
Step to reproduce bug:
nslookup blynk-cloud.com 8.8.8.8 <-- my current DNS
Nome: blynk-cloud.com
Address: 139.59.206.133 <-- blynk server with my data
nslookup blynk-cloud.com 202.46.32.187 <-- a chinese DNS
Address: 45.55.96.146 <-- chinese blynk server without my data
Inside the blynk configuration node in node-red change the address of the server with the Chinese one (ex. ws://45.55.96.146/websockets) now at login we get this:
8 Mar 23:45:50 - [info] [blynk-ws-client:Blynk - Test] Start connection: ws://45.55.96.146/websockets
8 Mar 23:45:50 - [info] [blynk-ws-client:Blynk - Test] SEND -> Cmd: LOGIN Id: 1 Data: "\u0002\u0000\u0001\u0000 ***************************7dcf7"
8 Mar 23:45:50 - [info] [blynk-ws-client:Blynk - Test] RECV <- Cmd: CONNECT_REDIRECT, Id: 1, len: 19, data: "139.59.206.133\u00008080"
Of course we need to change servers to connect with: ws://139.59.206.133:8080/websockets
For now it should be changed by hand, in the next release of the node-red library everything will happen automatically.
@trevordaniel2
Thanks for the availability, but I managed to reproduce the bug. Now I’ll try to correct it.
Meanwhile, if you want you can resolve blynk-cloud.com with nslookup on the server where it works and then manually copy the ip address on the AWS server, it should work.
regards
Gabriele
New release 0.4.0 of node-red-contrib-blynk-ws library!
Added
Changed
- Server port configuration and help message see Blynk Library 0.5.1
Fixed
- Invalid HW cmd: “pm” see iusse #3
- Protocol Log on message received and retrive right command body
regards
Gabriele
YAY! - It works!
I am connectified!
