Copy a group of widgets from one Tab to another
Hello Blynkers!
I need to copy a group of widgets (or the whole thing) from one Tab to another.
In other words, i need to duplicate one Tab without having to insert widgets one by one.
I do not want to use at this time Device Selector or Tiles solutions.
I was wondering, Is that possible
Best Regards
Kostas
Hi Kostas !!
I tried it , but unfortunaly, it is not possible.
Maybe @PeteKnight knows that ?
Alexis
I guess that if you’re using local server you could edit the project JSON file and add the widgets that way, but it’s probably more effort than it’s worth.
,"tabId":0,"label":"reed","isDefaultColor":false,"deviceId":0,"pinType":"VIRTUAL","pin":23,"pwmMode":
:joy_cat:
It’s easier if you use a JSON editor, but still plenty of scope to mess things up!
So, the answer is no (by means of the standard app functionality). In any case, thank you very much forv your time.
