Before creating the topic
- Search forum for similar topics
- Check http://docs.blynk.cc and http://help.blynk.cc/
- Add details :
• Blynk Library version
• Add your sketch code. Code should be formatted as example below.
```Trying to move project (currently working ok) to the ESP8266 Huzzah by Adafruit. In Arduino IDE 1.8.7 or 1.8.12, when i try to add the ESP8266, system says that it is not available.
