Hi fellow Blynkers,
I am quite new to the whole Blynk experience but have had some reasonable success getting started. I would like to build a plant soil moisture system that does not rely on MQTT and Blynk looks right for the job, I am however running into some problems with converting the data from the analog sensor into percentage.
Hardware:
- WEMOS D1 Mini
- Capacitive soil moisture sensor(generic) versio 1.0
I am able to read the sensor data using the following sketch:
char auth[] = "xxxxxxxxxxxxxxxxxxxxxxxx";
char ssid[] = "xxxxxxxxxxxxxxxxxxx";
char pass[] = "xxxxxxxxxxxxxxxxxxxx";
// Use Virtual pin 5 for uptime display
#define PIN_UPTIME V5
#define PIN_CALCULATION V6
// This function tells Arduino what to do if there is a Widget
// which is requesting data for Virtual Pin (5)
BLYNK_READ(PIN_UPTIME)
// This command writes Arduino's uptime in seconds to Virtual Pin (5)
Blynk.virtualWrite(PIN_UPTIME, millis() / 1000);
float moisture = PIN_UPTIME;
Serial.println(moisture);
What I am struggling with is converting this data to a percentage. The data range is between 540(dry) and 320(wet) and I would like to display this as percentage. So far my attempts to create a variable from PIN_UPTIME have not worked.
float soilMoisture = PIN_UPTIME
Does not return a value.
Thanks in advance.
