Isso funciona pra mim.
#define USE_SERIAL Serial
#include <ESP8266mDNS.h>
//#include <ESP8266HTTPClient.h>
#include <WiFiUdp.h>
#include <ArduinoOTA.h>
//#include <BlynkSimpleEsp8266_SSL.h> // 8441 is SSL port and 8442 is TCP port
//#define BLYNK_DEFAULT_FINGERPRINT "xx xx xx xx xx xx xx xx" // ensure no invisible characters in the fingerprint
#include <RF24Network.h>
#include <nRF24L01.h>
#include <RF24.h>
#include <string.h>
#include <Hash.h>
RF24 radio(4, 5); // Set up nRF24L01 radio on SPI bus plus pins 4 for CE and 15 for CSN
float h, t, f ;
int ti=0;
int pausa_receb_dados;
int pausa_APIget;
char ssid[] = "xxxxxx";
char pass[] = "xxxxxxx";
char server[] = "xxxxxxxxxx";
char auth[] = "xxxxxxxxxx";
void setup(){
ArduinoOTA.setPassword((const char *)"123");
ArduinoOTA.begin();
USE_SERIAL.setDebugOutput(true);
//Blynk.begin(auth, ssid, pass, server, 8441, BLYNK_DEFAULT_FINGERPRINT);
//Blynk.begin(auth,wifi,ssid, pass,8442 );
//Blynk.config(192.168.7.2,8442 );
//Blynk.begin (auth, "xxxxxxxxxx",8441);
//Blynk.begin(auth, wifi, ssid, pass,"xxxxxxxxxxxx");
//Blynk.begin(auth, wifi,"xxxxxxxxxx","xxxxxxxxxxxx");
Blynk.begin(auth, ssid, pass, IPAddress(xxx,xxx,xxx,xxx),8442);
radio.begin();
radio.setDataRate (RF24_250KBPS); // (RF24_250KBPS, RF24_1MBPS, RF24_2MBPS), RF24_1MBPS - 1Мбит/сек
radio.setPALevel(RF24_PA_LOW); // (RF24_PA_MIN=-18dBm, RF24_PA_LOW=-12dBm, RF24_PA_HIGH=-6dBm, RF24_PA_MAX=0dBm)
radio.openReadingPipe (1, 0x1234567890LL); // 0x1234567890
radio.startListening ();
pausa_receb_dados = timer.setInterval (2000L, recebe_tudo);
//pausa_APIget = timer.setInterval (5000L, APIget);
BLYNK_WRITE(V15){
String webhookdata = param.asStr();
Serial.print("webhookdata: ");
Serial.println(webhookdata);
Serial.print("valores: ");
Serial.println(f);
void recebe_tudo() {
float data[3];
if(radio.available()){ // Если в буфере имеются принятые данные
radio.read(&data, sizeof(data)); // Читаем данные в массив data и указываем сколько байт читать
h=data[0];
t=data[1];
f=data[2];
ti++;
Blynk.virtualWrite(V1, f);
Serial.println(f);
ArduinoOTA.handle();
//network.update();
