Controlling (from sketch) Which Stream is Plotted on Chart
Hi All.
Wondering if there’s any way for my HW device (ESP8266) to programmatically select which of the Data Streams connected to a Super Chart Widget are actually displayed on the chart? In my project the ESP8266 will be continually feeding updates to the Data Streams via virtual pins. But, I’d like it to also control which stream (or combination of streams) is plotted rather than having all 4 plotted all the time.
Thanks.
You can click on the legend to show/hide streams
Understood. But, I was hoping to do it programmatically from the hardware.
It may interfere with UX and most likely will not be implemented before thinking through it.
OK, thanks for considering it.
