I am trying to control a relay with both Blynk and an RF remote. You can see in the Loop section of the code I inserted some RF code that seems to work when Blynk is connected. The problem I am having is if Blynk isn’t connected the RF remote won’t control the dimmer.
Second problem I am having is turning the pin high or low ONLY while the RF remote is being pressed.
#include <FS.h>
#define BLYNK_DEBUG
#include <WidgetRTC.h>
#include <TimeLib.h>
#include "WemoSwitch.h"
#include "WemoManager.h"
#include "CallbackFunction.h"
#include <ESP8266mDNS.h>
#include <WiFiUdp.h>
#include <ArduinoOTA.h>
#include <DNSServer.h>
#include <ESP8266WebServer.h>
#include <WiFiManager.h>
#include <ArduinoJson.h>
#include <RCSwitch.h>
//on/off callbacks
void DimmerOn();
void DimmerOff();
WemoManager wemoManager;
WemoSwitch *Dimmer = NULL;
RCSwitch mySwitch = RCSwitch();
WidgetRTC rtc;
int timerID =1;
char blynk_token[34] = "*************************";
char name[9] ;
char currentTime[9];
bool clockSync = false;
bool shouldSaveConfig = false;
void saveConfigCallback () {
Serial.println("Should save config");
shouldSaveConfig = true;
void setup(){
Serial.begin(74880);
Serial.println();
mySwitch.enableReceive(12);
snprintf(name, 15, "Dimmer_%s", blynk_token);
//read configuration from FS json
Serial.println("mounting FS...");
if (SPIFFS.begin()) {
Serial.println("mounted file system");
if (SPIFFS.exists("/config.json")) {
//file exists, reading and loading
Serial.println("reading config file");
File configFile = SPIFFS.open("/config.json", "r");
if (configFile) {
Serial.println("opened config file");
size_t size = configFile.size();
// Allocate a buffer to store contents of the file.
std::unique_ptr<char[]> buf(new char[size]);
configFile.readBytes(buf.get(), size);
DynamicJsonBuffer jsonBuffer;
JsonObject& json = jsonBuffer.parseObject(buf.get());
json.printTo(Serial);
if (json.success()) {
Serial.println("\nparsed json");
strcpy(blynk_token, json["blynk_token"]);
Serial.println("failed to load json config");
configFile.close();
Serial.println("failed to mount FS");
//end read
// The extra parameters to be configured (can be either global or just in the setup)
// After connecting, parameter.getValue() will get you the configured value
// id/name placeholder/prompt default length
WiFiManagerParameter custom_blynk_token("blynk", "blynk token", blynk_token, 34);
//WiFiManager
//Local intialization. Once its business is done, there is no need to keep it around
WiFiManager wifiManager;
//set config save notify callback
wifiManager.setSaveConfigCallback(saveConfigCallback);
//set static ip
//wifiManager.setSTAStaticIPConfig(IPAddress(10,0,1,99), IPAddress(10,0,1,1), IPAddress(255,255,255,0));
//add all your parameters here
wifiManager.addParameter(&custom_blynk_token);
//reset settings - for testing
//wifiManager.resetSettings();
//set minimu quality of signal so it ignores AP's under that quality
//defaults to 10%
wifiManager.setMinimumSignalQuality();
//sets timeout until configuration portal gets turned off
//useful to make it all retry or go to sleep
//in seconds
//wifiManager.setTimeout(120);
//fetches ssid and pass and tries to connect
//if it does not connect it starts an access point with the specified name
//here "AutoConnectAP"
//and goes into a blocking loop awaiting configuration
if (!wifiManager.autoConnect(name, "password")) {
Serial.println("failed to connect and hit timeout");
delay(3000);
//reset and try again, or maybe put it to deep sleep
ESP.reset();
delay(5000);
Serial.println("connected...yeey :)");
//read updated parameters
strcpy(blynk_token, custom_blynk_token.getValue());
//save the custom parameters to FS
if (shouldSaveConfig) {
Serial.println("saving config");
JsonObject& json = jsonBuffer.createObject();
json["blynk_token"] = blynk_token;
File configFile = SPIFFS.open("/config.json", "w");
if (!configFile) {
Serial.println("failed to open config file for writing");
json.printTo(configFile);
configFile.close();
//end save
Serial.println("local ip");
wemoManager.begin();
// Format: Alexa invocation name, local port no, on callback, off callback
Dimmer = new WemoSwitch("Dimmer", 81, DimmerOn, DimmerOff);
wemoManager.addDevice(*Dimmer);
ArduinoOTA.setHostname(name);
ArduinoOTA.begin();
pinMode(4, OUTPUT);
pinMode(5, OUTPUT);
digitalWrite(4, HIGH);
digitalWrite(5, HIGH);
Blynk.config(blynk_token);
Blynk.connect(); // try to connect to server with default timeout
rtc.begin();
setSyncInterval(360);
timer.setInterval(59000L, activetoday); // Update Time Check every 59 seconds
void activetoday(){ // check if schedule #1 should run today
if(year() != 1970){
Blynk.syncVirtual(V1); // sync scheduler #1
Blynk.syncVirtual(V2); // sync scheduler #2
Blynk.syncVirtual(V9); // sync scheduler #3
Blynk.syncVirtual(V10); // sync scheduler #4
BLYNK_WRITE(V1) { // Scheduler #1 Time Input widget
TimeInputParam t(param);
int nowseconds = ((hour() * 3600) + (minute() * 60) + second());
int startseconds = (t.getStartHour() * 3600) + (t.getStartMinute() * 60);
int stopseconds = (t.getStopHour() * 3600) + (t.getStopMinute() * 60);
int dayadjustment = -1;
if(weekday() == 1){
dayadjustment = 6; // needed for Sunday Time library is day 1 and Blynk is day 7
if(t.isWeekdaySelected((weekday() + dayadjustment))){ //Time library starts week on Sunday, Blynk on Monday
//Schedule is ACTIVE today
if(nowseconds >= startseconds - 30 && nowseconds <= startseconds + 30 ){ // 62s on 60s timer ensures 1 trigger command is sent
Serial.println("Dimmer Opening... 1");
digitalWrite(4, LOW);
timer.deleteTimer(timerID);
timerID = timer.setTimeout(16000, OpenDimmer);
BLYNK_WRITE(V2) { // Scheduler #2 Time Input widget
if(weekday() == 1){
Serial.println("Dimmer Opening... 2");
BLYNK_WRITE(V9) { // Scheduler #3 Time Input widget
if(weekday() == 1){
Serial.println("Dimmer Closing... 3");
digitalWrite(5, LOW);
timerID = timer.setTimeout(16000, CloseDimmer);
BLYNK_WRITE(V10) { // Scheduler #4 Time Input widget
Serial.println(String("Time zone: ") + t.getTZ()); // Timezone is already added to start/stop time
Serial.println(String("Time zone offset: ") + t.getTZ_Offset()); // Get timezone offset (in seconds)
if(weekday() == 1){
Serial.println("Dimmer Closing... 4");
BLYNK_WRITE(V4) { // Open Dimmer
if (param.asInt() == 0) {
BLYNK_WRITE(V5) { // Close Dimmer
BLYNK_WRITE(V6) {
Serial.println("Dimmer Closing...");
void CloseDimmer() {
Blynk.virtualWrite(V6, HIGH);
Serial.println("Dimmer Closed");
BLYNK_WRITE(V7) {
Serial.println("Dimmer Opening...");
void OpenDimmer() {
Blynk.virtualWrite(V7, HIGH);
Serial.println("Dimmer Opened");
void DimmerOn() { // alexa open command
Serial.print("Alexa Dimmer Opening...");
void DimmerOff() { // alexa close command
Serial.print("Alexa Dimmer Closing...");
int start = 0;
BLYNK_WRITE(V20) {
if (param.asInt()) {
//button pressed
start = millis();
//button released
if (millis() - start > 5000) {
Serial.println("Reset WiFi...");
WiFi.disconnect(true);
delay(5000);
ESP.reset();
if (mySwitch.available()) {
int value = mySwitch.getReceivedValue();
if (mySwitch.getReceivedValue() == 8354) {
DimmerOff();}
mySwitch.resetAvailable();
ArduinoOTA.handle();
wemoManager.serverLoop();
