//6relay on off all on all off
char auth[] = "xxxxxxxxxxxxxxxxx";//token
char ssid[] = "xxxxxxx";
char pass[] = "xxxxxxxxxx";
/**************RELAY********************************/
const int relay1 = 15;//D8-GPIO15 relay1
const int relay2 = 13;//D7-GPIO13 relay2
const int relay3 = 12;//D6-GPIO12 relay3
const int relay4 = 14;//D5-GPIO14 relay4
const int relay5 = 4;//D2-GPIO4 relay5
const int relay6 = 5;//D1-GPIO5 relay6
WidgetLED led7(V13); //online
//buttonV1,V2, V3,V4,V5,V6 bistabil switch button android
//button V20,V21 monostabil pusch button android ON/OFF ALL
BLYNK_CONNECTED() {
Blynk.syncVirtual(V1);
Blynk.syncVirtual(V2);
Blynk.syncVirtual(V3);
Blynk.syncVirtual(V4);
Blynk.syncVirtual(V5);
Blynk.syncVirtual(V6);
Blynk.syncVirtual(V20);
Blynk.syncVirtual(V21);
/************BISTABIL switch button android*************/
BLYNK_WRITE(V1) // virtual V1 BISTABIL relay1
if (param.asInt()) {
digitalWrite(relay1, HIGH);
digitalWrite(relay1, LOW);
BLYNK_WRITE(V2) // virtual V2 BISTABIL relay2
digitalWrite(relay2, HIGH);
digitalWrite(relay2, LOW);
BLYNK_WRITE(V3) // virtual V3 BISTABIL relay3
digitalWrite(relay3, HIGH);
digitalWrite(relay3, LOW);
BLYNK_WRITE(V4) // virtual V4 BISTABIL relay4
digitalWrite(relay4, HIGH);
digitalWrite(relay4, LOW);
/**********BISTABIL switch button android*******************/
BLYNK_WRITE(V5) // virtual V5 BISTABIL relay5
digitalWrite(relay5, HIGH);
digitalWrite(relay5, LOW);
/*****************BISTABIL switch button android***************/
BLYNK_WRITE(V6) // virtual V6 BISTABIL relay6
digitalWrite(relay6, HIGH);
digitalWrite(relay6, LOW);
/*****************MONOSTABIL push button android***************/
BLYNK_WRITE(V20)//all ON relay1,2,3,4,5,6
Blynk.virtualWrite(V1, HIGH);
Blynk.virtualWrite(V2, HIGH);
Blynk.virtualWrite(V3, HIGH);
Blynk.virtualWrite(V4, HIGH);
Blynk.virtualWrite(V5, HIGH);
Blynk.virtualWrite(V6, HIGH);
/****************MONOSTABIL push button android****************/
BLYNK_WRITE(V21)//all OFF relay1,2,3,4,5,6
Blynk.virtualWrite(V1, LOW);
Blynk.virtualWrite(V2, LOW);
Blynk.virtualWrite(V3, LOW);
Blynk.virtualWrite(V4, LOW);
Blynk.virtualWrite(V5, LOW);
Blynk.virtualWrite(V6, LOW);
/***ONLINE*************/
void ledonline()
if (led7.getValue()) {
led7.off();
led7.on();
pinMode(relay1, OUTPUT);//relay1
pinMode(relay2, OUTPUT);
pinMode(relay3, OUTPUT);
pinMode(relay4, OUTPUT);
pinMode(relay5, OUTPUT);
pinMode(relay6, OUTPUT);
timer.setInterval(1000L, ledonline);
A nice and simple project, you done relay good
If you are interested, here is some coding shortcuts that should work…
From this…
to this…
digitalWrite(relay1, param.asInt()); // use value provided by widget
And this…
To this
BLYNK_WRITE(V20) // all ON relay 1,2,3,4,5,6
for (int i=1; i <= 6; i++) { // Loop from 1 to 6
digitalWrite(i, HIGH);
Blynk.virtualWrite(i, HIGH);
bad
for (int i = 1; i <= 16; i+=1) { // Loop from 1 to 6
char auth[] = "xxxxxxxxxxxxxxx";//token
char ssid[] = "xxxxx";
char pass[] = "xxxxx";
BLYNK_CONNECTED() {
digitalWrite(relay2, param.asInt()); // use value provided by widget
digitalWrite(relay3, param.asInt()); // use value provided by widget
digitalWrite(relay4, param.asInt()); // use value provided by widget
digitalWrite(relay5, param.asInt()); // use value provided by widget
digitalWrite(relay6, param.asInt()); // use value provided by widget
BLYNK_WRITE(V21) // all ON relay 1,2,3,4,5,6
digitalWrite(i, LOW);
Blynk.virtualWrite(i, LOW);
void ledonline()
led7.off();
led7.on();
