Control Multiple Digital Pins from one virtual pin
Hi, I am using Blynk bluetooth through galaxy s7 and and HC-05 bluetooth module. I am currently tring to write code to turn on 4 relays from one virtual pin. I get the “function definition is not allowed here” error as soon as the loop begans.
#include <DHT.h>
char auth[] = "a65f6c3231ec43c1a92f078d78c6a163";
SoftwareSerial SerialBLE(10, 11); // RX, TX
#define DHTPIN 9          // What digital pin we're connected to
#define DHTTYPE DHT11
# define All_zones 12
//relay control pins
#define RELAY_EN1 30
#define RELAY_EN2 31
#define RELAY_EN3 32
#define RELAY_EN4 33
//#define DHTTYPE DHT22   // DHT 22, AM2302, AM2321
//#define DHTTYPE DHT21   // DHT 21, AM2301
DHT dht(DHTPIN, DHTTYPE);
void sendSensor()
  float h = dht.readHumidity();
  float t = dht.readTemperature(true); // or dht.readTemperature(true) for Fahrenheit
  if (isnan(h) || isnan(t)) {
    return;
  Blynk.virtualWrite(V5, h," %" );
  Blynk.virtualWrite(V6, t," F");
 BLYNK_WRITE(V7) { // V10 is the virtual pin that toggles this operation
  if (param.asInt()==1) { // check if the widget data is true. this would be an int value if using a slider, but 0/1 logic applies
   digitalWrite(RELAY_EN1,LOW);
    digitalWrite(RELAY_EN2,LOW);
    digitalWrite(RELAY_EN3,LOW);
    digitalWrite(RELAY_EN4,LOW);
    digitalWrite(RELAY_EN1,HIGH);
    digitalWrite(RELAY_EN2,HIGH);
    digitalWrite(RELAY_EN3,HIGH);
    digitalWrite(RELAY_EN4,HIGH);
//pinMode(All_zones,INPUT);
  SerialBLE.begin(9600);
  Blynk.begin(SerialBLE, auth);
  dht.begin();
You are missing a closing bracket
Easy fix thank you so much
In future, when you post code on the forum, please add triple backticks at the beginning and end of the code so that it displays correctly.
I’ve edited your original post to fix the formatting.
