I am creating a simple project of temperature monitoring. The equipment used are Arduino Mega 2560 + Shield GSM Sim900 + DHT + DS18B20 probe. Everything works but every 1-2min reconnects with the server, sometimes several times in 1min. When I started this project and managed to work it was about 3 weeks working perfectly, towards some reconnection to the server 1 time a day. I’ve been having the reconnection problem for about 1 month and when he’s been working for several hours he is not able to connect to Blynk-Cloud again. Attached a screenshot of the team working 2min, and the complete code that I use. I have 3 sim cards, 2 from a company and both have the same problem, and 1 from another company that constantly gives me “login timeout” problems. I also tried this sketch on an arduino 1 and the result is the same.
The power supply of the Sim900 is 12VDC 2A
http://twitter.com/blynk_app
Attention! Please check out TinyGSM guide:
http://tiny.cc/tiny-gsm-readme
WARNING: GSM modem support is for BETA testing.
This example shows how value can be pushed from Arduino to
the Blynk App.
WARNING :
For this example you'll need Adafruit DHT sensor libraries:
https://github.com/adafruit/Adafruit_Sensor
https://github.com/adafruit/DHT-sensor-library
App project setup:
Value Display widget attached to V5
Value Display widget attached to V6
#define TINY_GSM_MODEM_SIM900
// Default heartbeat interval for GSM is 60
// If you want override this value, uncomment and set this option:
//#define BLYNK_HEARTBEAT 30
#include <TinyGsmClient.h>
#include <BlynkSimpleSIM800.h>
#include <DHT.h>
#include <OneWire.h>
char auth[] = "21ad99f32b6d479b83cdd30ff8c30d0a";
// Your GPRS credentials
// Leave empty, if missing user or pass
char apn[] = "internetmas"; //MASMOVIL
//char apn[] = "airtelwap.es"; //VODAFONE
char user[] = "";
char pass[] = "";
// Hardware Serial on Mega, Leonardo, Micro
//#define SerialAT Serial1
// or Software Serial on Uno, Nano
SoftwareSerial SerialAT(10, 11); // RX, TX
TinyGsm modem(SerialAT);
#define DHTPIN 2 // What digital pin we're connected to
//#define DHTTYPE DHT22 // DHT 22, AM2302, AM2321
//#define DHTTYPE DHT21 // DHT 21, AM2301
DHT dht(DHTPIN, DHTTYPE);
//Formalizar pines de activación de LEDS
int pin7 = 7;
int pin4 = 4;
int pin5 = 5;
int value = 0;
//Establecer entradas OneWire
OneWire ourWire1(3);
DallasTemperature sensors1(&ourWire1);
void sendSensor()
pinMode( pin5, OUTPUT);
int h = dht.readHumidity();
int t = dht.readTemperature(); // or dht.readTemperature(true) for Fahrenheit
int alarm = 28;
sensors1.requestTemperatures(); //Se envía el comando para leer la temperatura
float temp1= sensors1.getTempCByIndex(0); //Se obtiene la temperatura en ºC del sensor 1
if (isnan(h) || isnan(t)) {
return;
Blynk.virtualWrite(V5, h);
Blynk.virtualWrite(V6, t);
Blynk.virtualWrite(V7, temp1);
if (t > alarm)
digitalWrite(5, HIGH);
digitalWrite(5, LOW);
Serial.begin(9600); //9600
//Iniciar modulo sim900
digitalWrite(9, HIGH); // Descomentar para activar la alimentación de la tarjeta por Software
digitalWrite(9, LOW);
delay (5000); //Nos damos un tiempo para encender el GPRS y la alimentación de la tarjeta
sensors1.begin();
// Set GSM module baud rate
//SerialAT.begin(19200);
delay(3000);
modem.restart();
// Unlock your SIM card with a PIN
modem.simUnlock("9073"); //sim masmovil de puebas
//modem.simUnlock("3310"); //telefono trabajo
//modem.simUnlock("6367"); //sim personal Vodafone
dht.begin();
timer.setInterval(2000L, sendSensor); //1000L
//Condicion de fallo de corriente, apaga led verde y manda sms
pinMode( pin7, INPUT);
pinMode( pin4, OUTPUT);
value = digitalRead(pin7);
if (value == LOW)
digitalWrite(4, HIGH);
if (value == HIGH)
Serial.println("Enviando SMS...");
SerialAT.print("AT+CMGF=1\r"); //Configura el modo texto para enviar o recibir mensajes
SerialAT.println("AT+CMGS=\"656690402\""); //Numero al que vamos a enviar el mensaje
SerialAT.println("Fallo de corriente en el sistema."); // Texto del SMS
delay(100);
SerialAT.println((char)26); //Comando de finalización ^Z
delay(100);
SerialAT.println();
delay(5000); // Esperamos un tiempo para que envíe el SMS
Serial.println("SMS enviado");
