Dear Blynk Team
When I am connectkng to my esp32 showing this
I found 1st time this issue.
I hope you hear me soon
Best Regards
Maaz
Dear Blynk Team
Hi Huzefamaz1
Could you please provide more info on that case, such as sketch, app logs?
Are you sure there were no LAN/WAN issues during the provision?
Thanks for reply
I will create new template then it will work if I use my previous template I’d and device name it will won’t work I don’t know what’s the issue
Internet is no issue
Best Regards
Maaz
@Mark
Today too I have same issue sir I can’t find what the exactly issue why it’s happening, this happen I need to delete re add the device couple of times
Then it will connect to the network, there is no network connection issue because i everyday using same network for configuration esp32 , and code too no issue same code working with Blynk legency and Blynk iot too
I hope you hear me soon.
Best Regards
Maaz
Send your app log please.
Ok thanks I will send
