Hello, can someone help ?
05:48:17.294 -> [527] Connecting to abc
05:48:20.370 -> [3572] AT version:1.3.0.0(Jul 14 2016 18:54:01)
05:48:20.370 -> SDK version:2.0.0(656edbf)
05:48:20.370 -> compile time:Jul 19 2016 18:44:44
05:48:20.370 -> OK
05:48:25.415 -> [8629] +CIFSR:STAIP,"192.144.x.x"
05:48:25.415 -> +CIFSR:STAMAC,"ec:s:f:x:3c:78"
05:48:25.415 -> [8630] Connected to WiFi
05:48:38.509 -> [21702] Login timeout
05:48:52.530 -> [35714] Login timeout
05:49:06.556 -> [49724] Login timeout
05:49:20.567 -> [63734] Login timeout
05:49:34.588 -> [77744] Login timeout
05:49:48.609 -> [91754] Login timeout
-----CODE-----
#include <ESP8266_Lib.h>
char auth[] = "942d5f6a16024bff98bsadase6761";
char ssid[] = "abc6";
char pass[] = "kongsdong";
#define EspSerial Serial1
//#include <SoftwareSerial.h>
// Your ESP8266 baud rate:
#define ESP8266_BAUD 115200
ESP8266 wifi(&EspSerial);
// Set ESP8266 baud rate
I’ve moved your post to a new thread, and fixed your code formatting by adding triple backticks at the beginning and end of the code.
Please format your code correctly in future otherwise it will be deleted.
115200 is far too fast for Software Serial. I’d recommend 9600, but you must configure your ESP-01 to use the same baud rate using an AT command.
There are dozens of posts on this forum about how to do that, so do a little searching.
As long as you are using an Arduino Mega (and a few other models)… then Serial1 is a specific hardware serial port that will run fine at 115200… But you need to confirm all the other usual suspects as well.
Searching this forum for keywords like Arduino and ESP-01 holds ALL the answers for using Arduino with ESP-01…
Serial Crossover
ESP-01 Power
Arduino Code
Debug Diagnostics
Etc.
For example, I use this method for my Mega & ESP-01
//#define BLYNK_DEBUG // Advanced diagnostic data... also drastically slows entire sketch
#define BLYNK_PRINT Serial // This prints to Serial Monitor
#define BLYNK_USE_128_VPINS
#include <ESP8266_Lib.h> // ESP-01 Link
#include <BlynkSimpleShieldEsp8266.h> // ESP-01 Link
ESP8266 wifi(&Serial1); // Pins 18 & 19 on MEGA - For ESP-01 link
#define HTB 45 // Set HeartBeat LED pin.
char auth[] = "xxxxxxxxxx";
char ssid[] = "xxxxxxxxxx";
char pass[] = "xxxxxxxxxx";
char server[] = "blynk-cloud.com";
// or for local server - char server[] = "xxx.xxx.xxx.xxx";
int port = 8080;
Serial.begin(115200); // BLYNK_PRINT data - For Serial Monitor
Serial1.begin(115200); // Set baud rate - For ESP-01 link
wifi.setDHCP(1, 1, 1); //Enable dhcp in station mode and save in flash of esp8266
Blynk.config(wifi, auth, server, port);
if (Blynk.connectWiFi(ssid, pass)) {
Blynk.connect();
// Timed Lambda Function - UpTime counter
timer.setInterval(1000L, []() { // Run every second
Blynk.virtualWrite(V0, millis() / 1000); // Display the UpTime in Seconds to Widget on V0
}); // END Lambda Function
Thankyou for advice and visiting, sorry for my ignorance too sir
now i found the problem, that is my WIFI router is not stable, im trying to connect my esp to MIFI and boooomm, [22473] Ready (ping: 51ms). with no more login timeout
