Hi Blynk comm…
As of this morning my energy monitor project no longer connects to the Blynk server. Nothing has changed and I have several other projects that are working fine. The hardware part of the project is ok, it worked correctly for months but now it still has these problems.
What could it be about?
Spectre.
I’d start by rebooting your router, and if that doesn’t solve the problem take a look at what your serial monitor is showing.
Hi!
Hi, already done, restarted several times, firewall too. The other projects work fine.
the serial monitor just tells me it’s trying to connect to the server…
So you don’t feel like sharing then?
Do you mean the log of the serial? Anyway, now it’s back to working without doing anything…
