Connection lost after wifi access point reboot
I tried one by one but not solved. and a question: Can I add timer.setInterval to another void expect void setup ?
tried but nothing !
yes you can
As Alexis said… try first with only the sendUptime interval, if it works, try to comment out that and uncomment the PIRval, etc… maybe there is something that stops the exec of the program. As my last link I posted should work with your script. You only need to set the interval for the first function, all the other should be called with setTimeout…
Did you measure the execution time of your sendUptime?
he said that don’t work anymore
so I don’t understand
I checked the datasheet for the BMP180 and it takes 8 ~ 176ms to return the measurement, depending on accuracy…
can you write an example for me ? thanks
what happened if you delete all timers ?
if it works
try only first timer with 10000L
you don’t need to get value every seconds
10 seconds is good enough
When I delete all timers expect sendUptime there is no problem and connection restored after rebooting wifi router. But when I add function to sendUptime void or adding any timer the connection to server lost after rebooting wifi router
I don’t understand
this function works or not?
Try this:
-comment out all timers except sendUptime in setup. Than modify that function to include sthe setTimeout:
void sendUptime() { float temperature = sensor.getCelsiusHundredths(); Blynk.virtualWrite(5, (float)temperature/100); float humidity = sensor.getHumidityPercent(); Blynk.virtualWrite(6, humidity); // virtual pin uint16_t lux = lightMeter.readLightLevel(); Blynk.virtualWrite(4, lux); float bp = bmp.readPressure(); Blynk.virtualWrite(9,(float)bp/100); int callFunction2 = timer.setTimeout(1000, PIRval);//TWO not ONE }
Not worked.
Thanks. I will test tomorrow and tell the result
so you have a problem with that sensor
Can’t be helped.
BMP180 sensor ?
OK the problem solved by setting the sendUptime timer to 3000L ! but which sensor need 3000ms to measuring the data ? :thinking:
we were right!
3 seconds is very high.
anyway, that works.
yeah thanks. now working on 2000L without any problem.
anyway, you don’t need to check so many times
Don’t you?
I check my sensors 2 times hour.
