Connection ArduinoNano (ESP8266) -> Blynk fails
I use a Aduino Nano with an ESP8266. The attached sketch worked before, but fails to work now.
The terminal output shows that the msg [02|00|01|00] is repeated. The blynk app on my iPhone show the Arduino is offline.
What do I have to change?
    ___  __          __
   / _ )/ /_ _____  / /__
  / _  / / // / _ \/  '_/
 /____/_/\_, /_//_/_/\_\
        /___/ v0.4.3 on Arduino Nano
[41] Free RAM: 1017
[551] Connecting to MY_SSID
[3645] AT version:0.51.0.0(Nov 27 2015 13:37:21)
SDK version:1.5.0
compile time:Nov 27 2015 13:57:56
OK
[8813] +CIFSR:STAIP,"192.XXX.XXX.XXX"
+CIFSR:STAMAC,"18:fe:XX:XX:XX:XX"
[8818] Connected to WiFi
[20696] <[02|00|01|00] XXXXXXXX37364b07bde84b75XXXXXXXX
[30915] <[02|00|01|00] XXXXXXXX37364b07bde84b75XXXXXXXX
[41115] <[02|00|01|00] XXXXXXXX37364b07bde84b75XXXXXXXX
[51305] <[02|00|01|00] XXXXXXXX37364b07bde84b75XXXXXXXX
[61498] <[02|00|01|00] XXXXXXXX37364b07bde84b75XXXXXXXX
[71693] <[02|00|01|00] XXXXXXXX37364b07bde84b75XXXXXXXX
Sketch:
char ssid[] = "XXXX";
char password[] = "XXXX";
char token[] = "MY_TOKEN";
#define BLYNK_DEBUG
//#define BLYNK_NO_INFO
#include <ESP8266_Lib.h>
// Set ESP8266 Serial object
SoftwareSerial EspSerial(11, 12); // RX, TX
SimpleTimer updateTimer;
ESP8266 wifi(&EspSerial);
// variable defs left out
  // Set console baud rate
  Serial.begin(19200);
  EspSerial.begin(19200);
  Blynk.begin(token, ssid, password);
  //Serial.println("Starting ...");
  pinMode(relais, OUTPUT);  //Der Pin mit dem relais (Pin 5) ist jetzt ein Ausgang.
  pinMode(bewegung, INPUT); //Der Pin mit dem Bewegungsmelder (Pin 7) ist jetzt ein Eingang.
  //Serial.println("Starting timer!");
  //timer for resetting alarm
  updateTimer.setInterval(60000L, updateMeasure);
  updateTimer.run();
  if (bewegungsstatus == LOW) {
     bewegungsstatusNew=digitalRead(bewegung);
     // Licht sofort anschalten
     if (bewegungsstatusNew == HIGH) {
         bewegungsstatus = bewegungsstatusNew;
         updateMeasure();
  delay (1000);
it was solved by simply restarting my router.
–Peter
