Sorry, i don’t really understand. I think i already add a line of code after which is
} else if (smoke <= smoke_threshold && alert_sent == true) {
Serial.println("Temperature back to normal");
Serial.println();
alert_sent = false;
Serial.println();
alert_sent = false;
How does that show you, in the serial monitor, what the value of smoke is?
Yes.
I try to use this
float t = mq2.readTemperature();
But it appears that the readTemperature member of the MQ2 class is missing. So i think i could not use it. Should i use float lpg = mq2.readLPG(); instead?
The serial monitor shows nothing just can connect to the wifi and blynk
That’s because you haven’t done this…
I’d suggest that you read the specification sheet for the MQ-2 sensor. It’s a combustible gas sensor and has no temperature sensing capabilities.
I forgot to add line of code after that. Sorry, my mistake. Instead of using MQ2, I switched back to sensor.
This is the code:
#define BLYNK_TEMPLATE_ID "xxxxxxxxxxx"
#define BLYNK_DEVICE_NAME "xxxxxxxxxxx"
#define BLYNK_AUTH_TOKEN "xxxxxxxxxxx"
char ssid[] = "xxxxxxxxxxx";
char pass[] = "xxxxxxxxxxx";
int pinValue = 0;
#define Buzzer D5
#define Green D6
#define Red D7
#define Sensor A0
int sensor_threshold = 50;
bool alert_sent = false;
pinMode(Green, OUTPUT);
pinMode(Red, OUTPUT);
pinMode(Buzzer, OUTPUT);
pinMode(Sensor, INPUT);
timer.setInterval(1000L, notification);
BLYNK_WRITE(V0) {
pinValue = param.asInt();
void notification() {
int sensor = analogRead(Sensor);
Serial.print("Temperature = ");
Serial.println(sensor);
Serial.println();
Blynk.virtualWrite(V1, sensor);
if (sensor > sensor_threshold && alert_sent == false) {
digitalWrite(Green, HIGH);
digitalWrite(Red, LOW);
digitalWrite(Buzzer, LOW);
Blynk.logEvent("gas_leak_detected", String("The temperature is ") + Sensor);
Serial.println("High temperature alert!");
Serial.println("Blynk Alert Notification sent!");
Serial.println();
alert_sent = true;
} else if (sensor <= sensor_threshold && alert_sent == true) {
Serial.println();
alert_sent = false;
I assume it is already functional. It appears to already be capable of detecting the gas value.
I think that’s probably the wrong approach.
I chose to base my final IoT project on this gas leakage monitoring system from (https://srituhobby.com/iot-based-gas-leakage-monitoring-system/ )
Because I use this website’s code. It uses a sensor.
That project is being used to detect the butane from a unlit cigarette lighter.
You seem to be confused about whether you’re trying to detect smoke particles or temperature, and as I’ve already pointed-out the MQ-2 has no temperature sensing capabilities.
