Your screenshot doesn’t tell me much, an explanation of what you are attempting to do would be better.
If you are trying to connect your Blynk app to the WiFi of your device then that won’t work.
The Blynk app needs to connect to the Blynk server.
I was trying to connect ESP8266 to using Blynk.Edgent from the library.
I have edited my Template ID and Device Name according to what Ive got from the site.#define BLYNK_TEMPLATE_ID “” #define BLYNK_DEVICE_NAME “”
I use the IOS version.
After uploading the file to esp8266 the Blynk app 2.26.7(1) kept showing 3 dots.
Thank you.
In library(Blynk.Edgent)
There is no “char auth[] = “YourAuthToken”;”.
All information is about wifi. There is no information about Lora or sigfox.
