Connect with GSM
Hi dear.
I face problem while connecting app with ardoino i do every steps but still shows not connect yet
So please help me with that
You will find code below:
Follow us:                  http://www.fb.com/blynkapp
                            http://twitter.com/blynk_app
Attention! Please check out TinyGSM guide:
https://tiny.cc/tinygsm-readme
Change GPRS apm, user, pass, and Blynk auth token to run :slight_smile:
Feel free to apply it to any other example. It’s simple!
// Select your modem:
#define TINY_GSM_MODEM_SIM800
//#define TINY_GSM_MODEM_SIM900
//#define TINY_GSM_MODEM_M590
//#define TINY_GSM_MODEM_A6
//#define TINY_GSM_MODEM_A7
//#define TINY_GSM_MODEM_BG96
//#define TINY_GSM_MODEM_XBEE
// Default heartbeat interval for GSM is 60
// If you want override this value, uncomment and set this option:
//#define BLYNK_HEARTBEAT 30
#include <TinyGsmClient.h>
char auth[] = “s7IKp9a_CfEoeop7Gzhc1VYU9GqicPKh”;
// Your GPRS credentials
// Leave empty, if missing user or pass
char apn[] = “YourAPN”;
char user[] = “”;
char pass[] = “”;
// Hardware Serial on Mega, Leonardo, Micro
//#define SerialAT Serial1
// or Software Serial on Uno, Nano
SoftwareSerial SerialAT(7, 8); // RX, TX
TinyGsm modem(SerialAT);
// Set GSM module baud rate
SerialAT.begin(115200);
delay(3000);
Serial.println(“Initializing modem…”);
modem.restart();
// Unlock your SIM card with a PIN
//modem.simUnlock(“1234”);
@AH1 please edit your post (using the pencil icon at the bottom) and add triple backticks at the beginning and end of your code so that it displays correctly.
