I want to read the virtual pin V6 of second nodemcu and if the temperature value exceeds 32 i need to communicate the first nodemcu and turn on the dc motor on pin D2.
Is this possible?Please Help.
Kindly note: *I have created a blynk project with 2 devices (Both of my Nodemcu)
Yes, its possible.
You need to search for “Bridge” in the forum for examples of how to exchange data between the two devices.
There’s also an example here:
https://examples.blynk.cc/?board=ESP8266&shield=ESP8266%20WiFi&example=Widgets%2FBridge
and some documentation here:
thank you but how do i read the temperature value from V6 pin ??
(IN the example the value variable was a random boolean . I want it to be the V6 pin value)
When the temperature is written from the first board to V6, the BLYNK_WRITE(v6) callback on the second board will be triggered.
You then use the param.asInt() , or more probably param.asFloat(), command to capture the transmitted value and store it to a variable that you can then use elsewhere in your code.
here `is my code for the first node mcu
#include <DHT.h>
char auth[] = "X***0j"; //Enter the Auth code which was send by Blynk
char ssid[] = "rahul"; //Enter your WIFI Name
char pass[] = "rahul254"; //Enter your WIFI Password
WidgetBridge bridge1(V1);
BLYNK_CONNECTED() {
bridge1.setAuthToken("2e***96"); // Place the AuthToken of the second hardware here
#define DHTPIN 2 // Digital pin 4
DHT dht(DHTPIN, DHTTYPE);
void sendSensor()
float h = dht.readHumidity();
if (isnan(h) || isnan(t)) {
return;
Blynk.virtualWrite(V5, h); //V5 is for Humidity
Blynk.virtualWrite(V6, t); //V6 is for Temperature
float data = param.asFloat();
if (data>32.0){
bridge1.digitalWrite(D2, HIGH); // Digital Pin 2 with the dc motor on the second board will be set HIGH
dht.begin();
Sir, I am receiving “param was not declared in the scope error”
Please edit your post to add triple backticks at the beginning and end of your code.
Ive edited the code.The error is still not resolved
You’re getting the error because you’re not using the param.asFloat() command within a BLYNK_WRITE(vPin) callback.
Look at the example…
BLYNK_WRITE(V5)
int pinData = param.asInt(); // pinData variable will store value that came via Bridge
Also, using “data” as a variable name probably isn’t a great idea, I think it’s probably a reserved word.
#include <DHT.h>
char auth[] = "XPl**8OJ"; //Enter the Auth code which was send by Blink
BLYNK_CONNECTED() {
//#define DHTTYPE DHT22 // DHT 22, AM2302, AM2321
//#define DHTTYPE DHT21 // DHT 21, AM2301
void sendSensor()
return;
BLYNK_WRITE(V6)
int pindata = param.asInt(); // pinData variable will store value that came via Bridge
if (pindata>31.0){
bridge1.digitalWrite(D0, HIGH); // Digital Pin 9 on the second board will be set HIGH
dht.begin();
this code successfully compiled and uploaded but didnt work . Is there any existing issues in this code for the transmitting node mcu?
receiving node mcu has been coded this way:
char auth[] = "2e***96";
what changes are to be made here if any?
You don’t need the BLYNK_WRITE(V6)
function on the sending device. and use the actual GPIO number, not the Dpin Number on the board. In this case D6 is GPIO 12
void sendSensor()
return;
if (t >31.0){
bridge1.digitalWrite(12, HIGH); // Digital Pin 9/GPIO 12 on the second board will be set HIGH
No mater what, timer.setInterval(1000L, sendSensor);
is no bueno!
The consensus on this forum is that a DHT-sensor shouldn’t be read that frequently! Try 5000L
