I was wondering if there is an example of connecting data from Blink to Google home?
Say you’re collecting temperature info and want to retrieve it from Google home as well as Blink, how would this be done?
Thanks…
Thanks…
I guess you would need to find a way to do it in the first place (Googling “Send notification to Google Home” provides many options )
Then pick which method you wish to use that is most compatible with the Blynk process you are most comfortable with - email, SMS, Webhook, etc. and write some code to send your notification.
You can also try searching this forum for the words Google Home like I just did… there are a few ideas and suggestions already posted… perhaps you will find something already done?
