Connect Arduino over USB to local server
Hi
I’ve installed the local Blynk server on Raspbian and it works well
I’m using Arduino UNO via USB.
I can connect easily to the blynk server, but I can’t connect to the local server
When I try to compile the Sketch I get different errors
Blynk.begin(auth, serial, IPAddress (192,168,1,111));
gives this error
Arduino_Serial_USB:50: error: ‘serial’ was not declared in this scope
Blynk.begin(Serial, auth, IPAddress(192,168,1,111));
gives another error
‘IPAddress’ was not declared in this scope
What am I doing wrong?
Thank you
The key is in how you are connecting… In your case, since using USB, you make your adjustments in the USB script, not the sketch
for example… in blynk-ser.bat for Windows…
@echo off
setlocal EnableDelayedExpansion
REM === Edit these lines to match your need ===
set COMM_PORT=COM4
set COMM_BAUD=9600
set SERV_ADDR=xxx.xxx.xxx.xxx
set SERV_PORT=8442
http://help.blynk.cc/how-to-connect-different-hardware-with-blynk/arduino/usb-serial
Thank you
I think this is the solution
I will try it asap
Thnak you
It wokrs
