I am trying to create a low power application with deep_sleep on ESP8266. On wake up, the processor shall get some remembered values from Blync. So the idea is:
After start, log in to Blync and do a syncVirtual on a pin
Set a variable to the synced value using BLYNK_WRITE (since there is no virtualRead) triggered by syncVirtual
Increment the value and write it to the virtual pin
Go to sleep until next reboot
This is a proof of concept of course.
Its not working and I wonder how BLYNK_WRITE works. Will it be executed and the main program get interrupted? I think the sketch shows what I mean:
char auth[] = "fgdfgdfgdfgdf";
double onCycles = 0;
BLYNK_WRITE(V5)
onCycles = param.asDouble();
// This function sends the number of cycles the board was started
void doSomething()
onCycles++;
Blynk.virtualWrite(V5, onCycles);
digitalWrite(BUILTIN_LED, LOW); // Turn the LED on (Note that LOW is the voltage level
digitalWrite(BUILTIN_LED, HIGH); // Turn the LED on (Note that LOW is the voltage level
WiFi.disconnect();
ESP.deepSleep(10000000, WAKE_RF_DEFAULT); // Sleep for 10 seconds
pinMode(BUILTIN_LED, OUTPUT); // Initialize the BUILTIN_LED pin as an output
Blynk.begin(auth,"SSID", "PASSWORD");
// Wait until connected
Blynk.syncVirtual(V5);
doSomething();
Hello. It is not working cause setup is called only once (I suppose). You need to follow example for sync command and use BLYNK_CONNECTED for sync command. All other seems correct. Also I don’t see any place where you trying to reconnect again.
Thanks for looking into this Dmitry. Actually the idea is to reconnect on next boot. This is not visible in the sketch - but this is (AFAIK) the way deep_sleep works. It will reset the processor after a while and make it boot (if I manage to solder the right wire on my ESP-01). This is how I test it: Wait until it has disconnected, reset it. The expectation is that it comes up completely fresh but gets its old value from the sync. Just it doesn’t work.
I believe this is a bug in the ESP8266 implementation. I added some log output:
Serial started
[211] Connecting to Mydomain
[4313] Connected to WiFi
[4313] My IP: 192.168.1.84
[4313] Blynk v0.3.3-beta
[5001] Connecting to cloud.blynk.cc:8442
[5900] Ready (ping: 1ms).
Connected
[6150] Synced
[6255] Wrote V5: 1
Itt appears that BLYNK_WRITE is never called, but it should so. According to the doc page, syncAll should initiate it. May be there is a problem with the timing, because it must be executed somehow in the background like an interrupt routine.
Here is the code:
//#define BLYNK_DEBUG // Optional, this enables more detailed prints
char auth[] = "xxxxxxxxxxxxxxxxxxxxx";
WidgetLED led1(V3); //register to virtual pin 3
BLYNK_WRITE(V5)
BLYNK_LOG("Read V5: %f", onCycles);
void doSomething()
onCycles++;
BLYNK_LOG("Wrote V5: %d", int(onCycles));
led1.on();
led1.off();
WiFi.disconnect();
Serial.println("Serial started");
//pinMode(BUILTIN_LED, OUTPUT); // Initialize the BUILTIN_LED pin as an output - destroys serial protocol!
Blynk.begin(auth,"SSID", "Password");
Serial.println("Blynking");
Serial.println("Connected");
Blynk.syncAll();
BLYNK_LOG("Synced");
doSomething();
It’s more like it executes callback on interrupt. You can also try normal sleep mode which has memory retention (so you don’t need sleep mode) consumes around 0.31 mA according to data sheet.
Sorry I hit the send button by accident.
The log output is:
Serial started
[207] Connecting to xxxxx
[6309] Connected to WiFi
[6310] My IP: 192.168.1.9
[6310] Blynk v0.3.3-beta
[6310] Connecting to cloud.blynk.cc:8442
[7153] Ready (ping: 1ms).
[7409] Synced all
Connected
[7518] Wrote V5: 1
Looks like BLYNK_WRITE still is not executed.
Regarding conkerkh: The deep sleep works on my ESP-01 and its supposed to take µAmps. My hope is to use it with a 3V Lithium cell that runs for years waiting for an event (fire, window open alarm) and then wake up and send me some message. Theoretically this can be done without a “memory”, but if it knows some state that allows it to be smarter.
Blynk.syncAll(); is an asynchronous call!
it expects to continue looping until it gets the info from the server (BLYNK_WRITE is called only from Blynk.run() context).
My goal is to retrieve a value from last session. I cannot do this in setup, because Blynk.run has not been executed even once. I cannot do int in BLYNK_CONNECTED, because it will not get interrupted in order to magically set my global variable in the background. So I think, please correct me, each run of Blynk.run in the main loop checks for events and calls the BLYNK_XXX functions one by one in its own preferred orde.
This means if I want to use the value from last session, I need an event. There is only one event that is available: BLYNK_WRITE triggered by syncAll. Thats basically the way you do it in the sync example.
I may use the global variable somewhere else, but I should use a timer to wait until I am sure it has been set. Or I set a flag in the BLYNK_WRITE that tells another part of the program running in the main loop that something has been set. Although I just want to get a static value I need to catch its change in a self-made event chain.
Well, it probably can be done like this, but wouldn’t it be much more simple to have a command that just reads the virtual pin? Or are you afraid that folks may use your server as a hidden cloud memory storing illegal messages in virtual pins
