so if i have a float that i want to send to a value display widget to say something like
“base is X.X’C cooler” were X.X is a float
so i used this:
Blynk.virtualWrite(V55, "base is ", inletDifference, "'C cooler"); //inlet vs outlet calculation
and it outputs:
base is 5.613’C cooler
but i want it to output
base is 5.6’C cooler
is there an easy way to do this?
You need to use labeled display with formatting options and send only inletDifference
- http://docs.blynk.cc/#widgets-displays-labeled-value and you may use /pin.#/
formatting.
i want to use words in it - i can just type these into the labeled widget?
SUPERB!
cool thanks!
Labeled Value
Displays incoming data in a formatted way. It is a better version of ‘Value Display’ where you can add suffixes and prefixes on the app side, with no coding on the hardware.
Formatting options
For example: your sensor sends value of 12.6789 to Blynk application. [insert:]The following [delete:]Next formatting options are supported:
(just a couple of typos and syntax suggestions noted on the help page)
Or use sprintf to do a formatted copy to a string and do a blynk.virtualWrite of that string.
well that sounds terribly complicated!
but i might have to use this becuase i want the display to tell me
- warmest
- coolest
- driest
so off i go to learn how to sprintf…
Quite simple really.
char inletDifferenceMsg[44];
sprintf(inletDifferenceMsg, "base is %02.2f'C cooler", inletDifference);
Blynk.virtualWrite(V55, inletDifferenceFormatted); //inlet vs outlet calculation
