First time messing with Blynk and also pretty clueless on code. Trying to just turn the on board LED on and off on my Nano 33 IoT. Figure from there I can learn how to get a bit more complicated.
Using example code in the Arduino software and getting this error.
Arduino: 1.8.13 (Windows 10), Board: “Arduino MKR WiFi 1010”
Arduino_MKR1010:38:14: error: ‘qRtWUKwQL5zIiiyIzLCGP2O0syyBvOap’ was not declared in this scope
char auth[] =qRtWUKwQL5zIiiyIzLCGP2O0syyBvOap;
Arduino_MKR1010:42:14: error: ‘Dont’ was not declared in this scope
char ssid[] =Dont Blink 182;
C:\Users\EVANST~1\AppData\Local\Temp\arduino_modified_sketch_690722\Arduino_MKR1010.ino:42:14: note: suggested alternative: ‘uint’
uint
Arduino_MKR1010:43:14: error: ‘Starkey1’ was not declared in this scope
char pass[] =Starkey1;
C:\Users\EVANST~1\AppData\Local\Temp\arduino_modified_sketch_690722\Arduino_MKR1010.ino:43:14: note: suggested alternative: ‘Stream’
Stream
exit status 1
“Show verbose output during compilation”
