Compilation error
//AL Automation with Physical Button and ON OFF State Feedback
 #include <DNSServer.h>
 #include <ESP8266mDNS.h>  // For OTA with ESP8266
 #include <WiFiUdp.h>  // For OTA
 #include <ArduinoOTA.h>  // For OTA
 #include <WiFiManager.h>
 #include <ArduinoJson.h>
  //char ssid[] = "";
 //char pass[] = "";
 char blynk_token[34] = "YOUR_BLYNK_TOKEN";
 //bool shouldSaveConfig = false;
 void saveConfigCallback () {
 Serial.println("Should save config");
 //shouldSaveConfig = true;
void checkPhysicalButton();
int relay1State = LOW;
int pushButton1State = HIGH;
int relay2State = LOW;
int pushButton2State = HIGH;
int relay3State = LOW;
int pushButton3State = HIGH;
//#define SERVER "blynk-cloud.com "             // Comment-out if use Blynk hosted cloud service
//#define PORT 8442
#define RELAY_PIN_1      04   //D4
#define RELAY_PIN_2      05   //D5
#define RELAY_PIN_3      16   //D16
#define PUSH_BUTTON_1     12   //D12
#define PUSH_BUTTON_2    13   //D5
#define PUSH_BUTTON_3    14   //D7
#define VPIN_BUTTON_1    V1 // define in blynk app
#define VPIN_BUTTON_2    V2
#define VPIN_BUTTON_3    V3
#define OTA_HOSTNAME "Home_Automation"
BLYNK_CONNECTED() {
  Blynk.syncVirtual(VPIN_BUTTON_1);
  Blynk.syncVirtual(VPIN_BUTTON_2);
   Blynk.syncVirtual(VPIN_BUTTON_3);
  // Alternatively, you could override server state using:
 // Blynk.virtualWrite(VPIN_BUTTON_1, relay1State);
 // Blynk.virtualWrite(VPIN_BUTTON_2, relay2State);
 // Blynk.virtualWrite(VPIN_BUTTON_3, relay3State);
// When App button is pushed - switch the state
BLYNK_WRITE(VPIN_BUTTON_1) {
  relay1State = param.asInt();
  digitalWrite(RELAY_PIN_1, relay1State);
BLYNK_WRITE(VPIN_BUTTON_2) {
  relay2State = param.asInt();
  digitalWrite(RELAY_PIN_2, relay2State);
BLYNK_WRITE(VPIN_BUTTON_3) {
  relay3State = param.asInt();
  digitalWrite(RELAY_PIN_3, relay3State);
void checkPhysicalButton1(){   **// The error I mentioned below at the end of the code and on this line, with this '' {'' token**
  if (digitalRead(PUSH_BUTTON_1) == LOW) {
    // pushButton1State is used to avoid sequential toggles
    if (pushButton1State != LOW) {
      // Toggle Relay state
      relay1State = !relay1State;
      // Update Button Widget
    pushButton1State = LOW;
void checkPhysicalButton2(){
  if (digitalRead(PUSH_BUTTON_2) == LOW) {
    // pushButton2State is used to avoid sequential toggles
    if (pushButton2State != LOW) {
      relay2State = !relay2State;
    pushButton2State = LOW;
void checkPhysicalButton3(){
  if (digitalRead(PUSH_BUTTON_3) == LOW) {
    // pushButton3State is used to avoid sequential toggles
    if (pushButton3State != LOW) {
      relay3State = !relay3State;
    pushButton3State = LOW;
 Serial.println();
  pinMode(RELAY_PIN_1, OUTPUT);
  pinMode(PUSH_BUTTON_1, INPUT_PULLUP);
  pinMode(RELAY_PIN_2, OUTPUT);
  pinMode(PUSH_BUTTON_2, INPUT_PULLUP);
  pinMode(RELAY_PIN_3, OUTPUT);
  pinMode(PUSH_BUTTON_3, INPUT_PULLUP);
   //clean FS, for testing
  //SPIFFS.format();
  //read configuration from FS json
  Serial.println("mounting FS...");
  if (SPIFFS.begin()) {
    Serial.println("mounted file system");
    if (SPIFFS.exists("/config.json")) {
      //file exists, reading and loading
      Serial.println("reading config file");
      File configFile = SPIFFS.open("/config.json", "r");
      if (configFile) {
        Serial.println("opened config file");
        size_t size = configFile.size();
        // Allocate a buffer to store contents of the file.
        std::unique_ptr<char[]> buf(new char[size]);
        configFile.readBytes(buf.get(), size);
        DynamicJsonBuffer jsonBuffer;
        JsonObject& json = jsonBuffer.parseObject(buf.get());
        json.printTo(Serial);
        if (json.success()) {
          Serial.println("\nparsed json");
          //strcpy(mqtt_server, json["mqtt_server"]);
          //strcpy(mqtt_port, json["mqtt_port"]);
          strcpy(blynk_token, json["blynk_token"]);
          Serial.println("failed to load json config");
    Serial.println("failed to mount FS");
  //end read
  // The extra parameters to be configured (can be either global or just in the setup)
  // After connecting, parameter.getValue() will get you the configured value
  // id/name placeholder/prompt default length
  //WiFiManagerParameter custom_mqtt_server("server", "mqtt server", mqtt_server, 40);
  //WiFiManagerParameter custom_mqtt_port("port", "mqtt port", mqtt_port, 6);
  WiFiManagerParameter custom_blynk_token("blynk", "blynk token", blynk_token, 33);
  //WiFiManager
  //Local intialization. Once its business is done, there is no need to keep it around
  WiFiManager wifiManager;
  //set config save notify callback
  wifiManager.setSaveConfigCallback(saveConfigCallback);
  //set static ip
  //wifiManager.setSTAStaticIPConfig(IPAddress(10,0,1,99), IPAddress(10,0,1,1), IPAddress(255,255,255,0));
  //add all your parameters here
  //wifiManager.addParameter(&custom_mqtt_server);
  //wifiManager.addParameter(&custom_mqtt_port);
  wifiManager.addParameter(&custom_blynk_token);
  //reset settings - for testing
  //wifiManager.resetSettings();
  //set minimu quality of signal so it ignores AP's under that quality
  //defaults to 8%
  //wifiManager.setMinimumSignalQuality();
  //sets timeout until configuration portal gets turned off
  //useful to make it all retry or go to sleep
  //in seconds
  //wifiManager.setTimeout(120);
  //fetches ssid and pass and tries to connect
  //if it does not connect it starts an access point with the specified name
  //here  "AutoConnectAP"
  //and goes into a blocking loop awaiting configuration
  if (!wifiManager.autoConnect("Wifi_Int_0002", "password")) {
    Serial.println("failed to connect and hit timeout");
    delay(3000);
    //reset and try again, or maybe put it to deep sleep
    ESP.reset();
    delay(5000);
  Serial.println("connected...yeey :)");
  //read updated parameters
  //strcpy(mqtt_server, custom_mqtt_server.getValue());
  //strcpy(mqtt_port, custom_mqtt_port.getValue());
  strcpy(blynk_token, custom_blynk_token.getValue());
  //save the custom parameters to FS
  if (shouldSaveConfig) {
    Serial.println("saving config");
    JsonObject& json = jsonBuffer.createObject();
    //json["mqtt_server"] = mqtt_server;
    //json["mqtt_port"] = mqtt_port;
    json["blynk_token"] = blynk_token;
    File configFile = SPIFFS.open("/config.json", "w");
    if (!configFile) {
      Serial.println("failed to open config file for writing");
    json.printTo(configFile);
    configFile.close();
    //end save
  //Serial.println("local ip");
  //Serial.println(WiFi.localIP());
  Blynk.config(blynk_token);
  bool result = Blynk.connect();
if (result != true)
  Serial.println("BLYNK Connection Fail");
  Serial.println(blynk_token);
  ESP.reset();
  delay (5000);
  Serial.println("BLYNK Connected");
  ArduinoOTA.setHostname(OTA_HOSTNAME);  // For OTA - Use your own device identifying name
  ArduinoOTA.begin();  // For OTA
  // Setup a function to be called every 100 ms
  timer.setInterval(100L, checkPhysicalButton1);
  timer.setInterval(113L, checkPhysicalButton2);
  timer.setInterval(126L, checkPhysicalButton3);
  ArduinoOTA.handle();  // For OTA
Can someone help me, is giving this error when compiling the code,
(a function definition is not allowed here before the ‘{’ token).[quote=“luciano0609, post:1, topic:45363, full:true”]
 //char ssid[] = "";
 //char pass[] = "";
//#define PORT 8442
BLYNK_CONNECTED() {
 Serial.println();
  //SPIFFS.format();
      if (configFile) {
  //end read
  //WiFiManager
  //set static ip
  //defaults to 8%
  //in seconds
    delay(3000);
    ESP.reset();
    delay(5000);
    if (!configFile) {
    configFile.close();
    //end save
if (result != true)
  ESP.reset();
  delay (5000);
I made a comment on the line that is giving the error, it is highlighted in bold.
In this line (void checkPhysicalButton1 () {
Currently, the only way for someone to help you is for them to copy your code into their Arduino IDE, track-down and install the included libraries, make an educated guess at which board to choose, then try compiling your code to see the full error message and whereabouts in the code it occurs.
If you’d included the full details of the compilation error message then they’d know which line of code to start looking at, and would probably been able to give you an answer by mow.
Help us to help you!
You don’t have your start and end braces matched up properly
Can you help me.
In fact, I took this example from the Internet and tried to include the WifiManager library to change Blynk’s ssid, password and token via cell phone.
I’m also having difficulties when I don’t have Internet, I can’t physically turn off or turn on the light using the button.
if you click on the brace it will show where it thinks the other end should be if it is not where you expect then there is a problem. there should be as many ending as starting. I am sure you can figure it out
I’m a layman in programming, what support do you talk about?
Why won’t you post full details of the compilation error?
This is the last time I’ll ask before I stop looking at this thread.
you asked me to detail,that’s what I tried to do
Looks like you are missing the closing bracket to this function.
What I said was…
There is a significant difference.
Oops, Toro Blanco, everything is fine. Can you help me fix this code?
I also needed to turn the relay on and off using the local network without relying on the Internet. Can you help me do this?
The thing is people are willing to help if you are willing to put some effort into the project. Nobody wants to do this for you.
This example should get you going on combining blynk and wifimanager.
As to being able to control the relay without wifi, you’ll probably have to add a button or switch.
