While compiling a simple code with BlynkEdgent and AsyncElegantOTA library an error is displayed like a conflicting declaration ‘AsyncWebServer server’
In file included from C:\Users\Rames\OneDrive\Documents\Arduino\libraries\AsyncElegantOTA\src/AsyncElegantOTA.h:21,
from C:\Users\Rames\OneDrive\Documents\Arduino\Edgent_ESP8266\Edgent_ESP8266.ino:20:
C:\Users\Rames\OneDrive\Documents\Arduino\libraries\ESPAsyncWebServer-master\src/ESPAsyncWebServer.h:62:18: error: 'HTTP_GET' conflicts with a previous declaration
62 | HTTP_GET = 0b00000001,
In file included from sketch\ConfigMode.h:3,
from sketch\BlynkEdgent.h:25,
from C:\Users\Rames\OneDrive\Documents\Arduino\Edgent_ESP8266\Edgent_ESP8266.ino:19:
C:\Users\Rames\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WebServer\src/ESP8266WebServer.h:47:29: note: previous declaration 'HTTPMethod HTTP_GET'
47 | enum HTTPMethod { HTTP_ANY, HTTP_GET, HTTP_HEAD, HTTP_POST, HTTP_PUT, HTTP_PATCH, HTTP_DELETE, HTTP_OPTIONS };
C:\Users\Rames\OneDrive\Documents\Arduino\libraries\ESPAsyncWebServer-master\src/ESPAsyncWebServer.h:63:18: error: 'HTTP_POST' conflicts with a previous declaration
63 | HTTP_POST = 0b00000010,
C:\Users\Rames\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WebServer\src/ESP8266WebServer.h:47:50: note: previous declaration 'HTTPMethod HTTP_POST'
C:\Users\Rames\OneDrive\Documents\Arduino\libraries\ESPAsyncWebServer-master\src/ESPAsyncWebServer.h:64:18: error: 'HTTP_DELETE' conflicts with a previous declaration
64 | HTTP_DELETE = 0b00000100,
C:\Users\Rames\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WebServer\src/ESP8266WebServer.h:47:83: note: previous declaration 'HTTPMethod HTTP_DELETE'
C:\Users\Rames\OneDrive\Documents\Arduino\libraries\ESPAsyncWebServer-master\src/ESPAsyncWebServer.h:65:18: error: 'HTTP_PUT' conflicts with a previous declaration
65 | HTTP_PUT = 0b00001000,
C:\Users\Rames\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WebServer\src/ESP8266WebServer.h:47:61: note: previous declaration 'HTTPMethod HTTP_PUT'
C:\Users\Rames\OneDrive\Documents\Arduino\libraries\ESPAsyncWebServer-master\src/ESPAsyncWebServer.h:66:18: error: 'HTTP_PATCH' conflicts with a previous declaration
66 | HTTP_PATCH = 0b00010000,
C:\Users\Rames\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WebServer\src/ESP8266WebServer.h:47:71: note: previous declaration 'HTTPMethod HTTP_PATCH'
C:\Users\Rames\OneDrive\Documents\Arduino\libraries\ESPAsyncWebServer-master\src/ESPAsyncWebServer.h:67:18: error: 'HTTP_HEAD' conflicts with a previous declaration
67 | HTTP_HEAD = 0b00100000,
C:\Users\Rames\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WebServer\src/ESP8266WebServer.h:47:39: note: previous declaration 'HTTPMethod HTTP_HEAD'
C:\Users\Rames\OneDrive\Documents\Arduino\libraries\ESPAsyncWebServer-master\src/ESPAsyncWebServer.h:68:18: error: 'HTTP_OPTIONS' conflicts with a previous declaration
68 | HTTP_OPTIONS = 0b01000000,
C:\Users\Rames\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WebServer\src/ESP8266WebServer.h:47:96: note: previous declaration 'HTTPMethod HTTP_OPTIONS'
C:\Users\Rames\OneDrive\Documents\Arduino\libraries\ESPAsyncWebServer-master\src/ESPAsyncWebServer.h:69:18: error: 'HTTP_ANY' conflicts with a previous declaration
69 | HTTP_ANY = 0b01111111,
C:\Users\Rames\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WebServer\src/ESP8266WebServer.h:47:19: note: previous declaration 'HTTPMethod HTTP_ANY'
Edgent_ESP8266:23:16: error: conflicting declaration 'AsyncWebServer server'
23 | AsyncWebServer server(7775);
In file included from sketch\BlynkEdgent.h:25,
sketch\ConfigMode.h:60:18: note: previous declaration as 'ESP8266WebServer server'
60 | ESP8266WebServer server(80);
exit status 1
• NodeMCU 1.0
• Using Blynk server
• Blynk Library version 1.1.0
#define BLYNK_TEMPLATE_ID "TMPL_zFqOJa_"
#define BLYNK_DEVICE_NAME "Sump Motor IoT ESP8266"
//#define BLYNK_DEBUG
#define APP_DEBUG
// Uncomment your board, or configure a custom board in Settings.h
//#define USE_SPARKFUN_BLYNK_BOARD
//#define USE_NODE_MCU_BOARD
//#define USE_WITTY_CLOUD_BOARD
//#define USE_WEMOS_D1_MINI
#include "BlynkEdgent.h"
#include <AsyncElegantOTA.h>
#define F(string_literal) (reinterpret_cast<const __FlashStringHelper *>(PSTR(string_literal)))
delay(100);
BlynkEdgent.begin();
BlynkEdgent.run();
