Communicate two devices
I have two Blynk devices. One in the room and other connected to Boiler. I want to send on/off command to Boiler side device accordining to room temperature. I created two devices in Blynk Console and adjusted the widgets. Everyting works charm but two devices doesnt comunicate with each other.
Thanks in advance…
You can use automation which is the easiest way.
https://docs.blynk.io/en/concepts/automations/forward-device-data
Thank you very much… :smile: You save my life… :pray:
