@skrankk in order to find each sensor’s unique ID, I have used this program, marked each address into a document, then marked each sensor with an identifying mark corresponding to the address in said document.
// This sketch looks for 1-wire devices and
// prints their addresses (serial number) to
// the UART, in a format that is useful in Arduino sketches
// Tutorial:
// http://www.hacktronics.com/Tutorials/arduino-1-wire-address-finder.html
#include <OneWire.h>
OneWire ds(3); // Connect your 1-wire device to pin 3 (Arduino pin numbering)
void setup(void) {
discoverOneWireDevices();
void discoverOneWireDevices(void) {
byte i;
byte present = 0;
byte data[12];
byte addr[8];
Serial.print("Looking for 1-Wire devices...\n\r");
while(ds.search(addr)) {
Serial.print("\n\rFound \'1-Wire\' device with address:\n\r");
for( i = 0; i < 8; i++) {
Serial.print("0x");
if (addr[i] < 16) {
Serial.print('0');
Serial.print(addr[i], HEX);
if (i < 7) {
Serial.print(", ");
if ( OneWire::crc8( addr, 7) != addr[7]) {
Serial.print("CRC is not valid!\n");
Serial.print("\n\r\n\rThat's it.\r\n");
ds.reset_search();
void loop(void) {
// nothing to see here
