Combine esp8266,arduino and blynk app, without internet connection
hi i’m new in blynk community and using blynk app, so need help with project, i will control motor dc and servo in arduino with blynk app, and im using esp8266 as Access Point to communicated with arduino, but what i can do it this without internet connection?
Run a local server on your local network. Use an Raspberry Pi or linux machine. See the docs
All your ESP’s connected to the same network, pointing to the internal local server IP.
Then you can connect to the local IP in the mobile app when you’re connect to the local network.
ohh so i has using blynk server for this, ok i try, thanks for reply @jamin
