Combine bmp280 code and blynk switch code
i want to make a project that my room lamp are controlled by phone and i can see the temperature, pressure, and altitude but i got problem when combining these two codes
below is my switch code
#include <WiFi.h>
#include <BlynkSimpleEsp32.h>
char auth[] = "xxxxxxxxxx";
char ssid[] = "xxxx";
char pass[] = "xxxxxxx";
// Set your LED and physical button pins here
const int ledPin1 = 13;
const int ledPin2 = 14;
const int ledPin3 = 15;
const int ledPin4 = 16;
const int btnPin1 = 32;
const int btnPin2 = 33;
const int btnPin3 = 34;
const int btnPin4 = 35;
void checkPhysicalButton();
int led1State = LOW;
int btn1State = HIGH;
int led2State = LOW;
int btn2State = HIGH;
int led3State = LOW;
int btn3State = HIGH;
int led4State = LOW;
int btn4State = HIGH;
// Every time we connect to the cloud...
BLYNK_CONNECTED() {
  Blynk.syncVirtual(V12);
  Blynk.syncVirtual(V13);
  Blynk.syncVirtual(V14);
  Blynk.syncVirtual(V15);
  // Alternatively, you could override server state using:
  //Blynk.virtualWrite(V12, led1State);
  //Blynk.virtualWrite(V13, led2State);
  //Blynk.virtualWrite(V14, led3State);
  //Blynk.virtualWrite(V15, led4State);
// When App button is pushed - switch the state
BLYNK_WRITE(V12) {
  led1State = param.asInt();
  digitalWrite(ledPin1, led1State);
 BLYNK_WRITE(V13) {
  led2State = param.asInt();
  digitalWrite(ledPin2, led2State);
BLYNK_WRITE(V14) {
  led3State = param.asInt();
  digitalWrite(ledPin3, led3State);
BLYNK_WRITE(V15) {
  led4State = param.asInt();
  digitalWrite(ledPin4, led4State);
  if (digitalRead(btnPin1) == LOW) {
    // btn1State is used to avoid sequential toggles
    if (btn1State != LOW) {
      // Toggle LED state
      led1State = !led1State;
      // Update Button Widget
    btn1State = LOW;
    btn1State = HIGH;
  if (digitalRead(btnPin2) == LOW) {
    if (btn2State != LOW) {
      // Toggle LED state
      led2State = !led2State;
    btn2State = LOW;
    btn2State = HIGH;
  if (digitalRead(btnPin3) == LOW) {
    if (btn3State != LOW) {
      // Toggle LED state
      led3State = !led3State;
    btn3State = LOW;
    btn3State = HIGH;
  if (digitalRead(btnPin4) == LOW) {
    if (btn4State != LOW) {
      // Toggle LED state
      led4State = !led4State;
    btn4State = LOW;
    btn4State = HIGH;
  pinMode(ledPin1, OUTPUT);
  pinMode(btnPin1, INPUT_PULLUP);
  pinMode(ledPin2, OUTPUT);
  pinMode(btnPin2, INPUT_PULLUP);
  pinMode(ledPin3, OUTPUT);
  pinMode(btnPin3, INPUT_PULLUP);
  pinMode(ledPin4, OUTPUT);
  pinMode(btnPin4, INPUT_PULLUP);
  // Setup a function to be called every 100 ms
  timer.setInterval(500L, checkPhysicalButton);
and below is my bmp280 sensor code
#include <WiFi.h>
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_BMP280.h>
char auth[] = "...";
char ssid[] = "...";  //Enter your WIFI Name
char pass[] = "...";  //Enter your WIFI Password
#define BMP_SCK 18
#define BMP_MISO 19
#define BMP_MOSI 23
#define BMP_CS 5
Adafruit_BMP280 bme; // I2C
void sendSensor()
  float a = bme.readTemperature();
  float b = bme.readPressure()/100;
  float c = bme.readAltitude(1015.80);
  Blynk.virtualWrite(V7, a);  //V7 is for Temperature on BMP280
  Blynk.virtualWrite(V8, b);  //V8 is for Pressure on BMP280
  Blynk.virtualWrite(V9, c);  //V9 is for Altitude on BMP280
  bme.begin();
please help me who can combine these two code, sorry for bad english
Where exactly did these two pieces of code come from?
How are you controlling your room lamp? Presumably using a relay, but is that active HIGH or LOW? Is it a single lamp, or three lamps as in the sketch?
Are you using a physical switch to turn the lamp(s) on and off, or just the Blynk app?
What sort of MCU are you using?
sorry i post the wrong code, but i have already post the right code
  1. these code are come from this community and i want to combine these two codes for my bedroom
  2. i using relay, the relay are active low, i have four lamp at my room
  3. i want to use both of them for my project, physical button that syncronized with Blynk app
  4. i use esp32 NodeMCU module
would you help me to finish this project?
