am using nodemcu
anybody please help me to work smoothly without connecting to blynk server or wifi while booting…
am using nodemcu
@Abin_Paul please edit your post, using the pencil icon at the bottom, and add triple backticks at the beginning and end of the your code so that it displays correctly correctly.
I actualy needs to work the main loop even if not connected to server… (something like timeout option ???) if connected fine… but dont stuck over there untill getting connected.
What you need to do is edit your post, otherwise your unformatted code will be deleted.
Once you’ve done that then I and other forum members will be happy to point you towards a solution.
