Sorry. Was not that clear as i was unsure how i wanted to go about it.
I am wanting to start and reset a timer but if i can just get the timer going for now. There maybe a better way of getting it to work what i have at the moment is as follows.
void fermentTime()
char buffer[100];
long lastTime = 0;
long fermMinutes = 0;
long fermHours = 0;
long fermDays = 0;
long fermWeeks = 0;
if(millis()-lastTime > 60000){
fermMinutes++;
lastTime = millis();
if(fermMinutes > 60){
fermHours++;
fermMinutes = 0;
if(fermHours > 24){
fermDays++;
fermHours = 0;
if(fermDays > 7){
fermWeeks++;
fermDays = 0;
sprintf(buffer, "Fermentation Timer %ld:%ld:%ld", fermHours, fermMinutes, lastTime );
Serial.println (buffer);
Blynk.virtualWrite(V15, fermWeeks, fermHours, fermMinutes, lastTime);
// Timers
timer.setInterval(1000, myTimerEvent); //Send runtime every sec to blynk
timer.setTimeout(5000, startLCD); //LCD Start
timer.setInterval(2000, fermentTime); //Send runtime every sec to blynk
timer.setInterval(4000, sendDS18B20); //Send DS18B20 data every 4 sec to blynk
// timer.setInterval(5000, sendDHT); //Send DHT data every 5 sec to blynk
timer.setInterval(10000, clockDisplay); //Update blynk lcd time every 10 sec
timer.setInterval(4500, serialDS18B20); //Update serial mon data every 4.5 sec
// timer.setInterval(5500, serialDHT); //Update serial mon data every 5.5 sec
timer.setInterval(10000, serialCLOCKOUT); //Update serial mon data every 6.5 sec
timer.setInterval(5000, timeLCD); //Update LCD time every 5 sec
timer.setInterval(10000, tempsLCD); //Update LCD temps every 10 sec
But this isnt really working out for me. It mills got to 60000 and then fermMinutes moves to one but when millis gets to 120000 nothing happens.
I have changed all of the timer now to something that works.
I am trying to get the timer to start with a virtual button and stop and reset when i turn it off. If you could point me in the right direction because what i am doing is not working.
#include "arduino.h"
// #region Blynk & Esp8266 Setup.
#include <ESP8266_Lib.h>
// Blynk Project Auth Token from the Blynk App.
char auth[] = "!!!!!!!!!!";
// WiFi AP Settings.
char ssid[] = "ubnt-pico";
char pass[] = "!!!!!!";
// Set ESP8266 Serial object
#define EspSerial Serial
// ESP8266 baud rate:
#define ESP8266_BAUD 115200
ESP8266 wifi(&EspSerial);
// #endregion
// #region Fermentation Timer
char fermTimeBuffer[100];
int fermSeconds = 0;
int fermMinutes = 0;
int fermHours = 0;
int fermDays = 0;
// int fermWeeks = 0;
int HighMillis=0;
int Rollover=0;
// #endregion
// #region On Timer Function
void myTimerEvent()
Blynk.virtualWrite(V6, millis() / 1000);
// #endregion
// #region Fermentation Timer Function
void fermentTime()
//** Making Note of an expected rollover *****//
if(millis()>=3000000000){
HighMillis=1;
//** Making note of actual rollover **//
if(millis()<=100000&&HighMillis==1){
Rollover++;
HighMillis=0;
long secsUp = millis()/1000;
fermSeconds = secsUp%60;
fermMinutes = (secsUp/60)%60;
fermHours = (secsUp/(60*60))%24;
fermDays = (Rollover*50)+(secsUp/(60*60*24)); //First portion takes care of a rollover [around 50 days]
sprintf(fermTimeBuffer, "Fermentation Timer %d:%d:%d", fermHours, fermMinutes, fermSeconds );
Serial.println (fermTimeBuffer);
Blynk.virtualWrite(V15, fermTimeBuffer);
timer.setInterval(1000, fermentTime); //Send runtime every sec to blynk
// #endregion
// #region Fermentation Timer Start Functions
BLYNK_WRITE(V30)
fermtimeStart = param.asInt();
if (fermtimeStart == 1)
fermentTime();
else if (fermtimeStart == 0)
long Day= 0;
int Hour = 0;
int Minute= 0;
int Second= 0;
int HighMillis= 0;
int Rollover= 0;
// Debug console &ESP8266 baud rate
Blynk.begin(auth, wifi, ssid, pass, "blynk-cloud.com", 8442);
// Begin synchronizing and starting sensors
rtc.begin();
// dht.begin();
sensors.begin();
// Timers
timer.setTimeout(1500, startLCD); //LCD Start
// timer.setInterval(1000, fermentTime); //Send runtime every sec to blynk
BLYNK_WRITE(30);
