Code lines causing Blynk on Wemos D1 to disconnect from WIFI (and its not Delay related)
Hello all, everytime my code reaches a certain line of codes, the Wemos disconnects and this is causing me much anxiety. Below is the situation:
This code is used in my auto brewing code. I use the terminal widget to input Hop addition times. Then during the boil, when the elapsed time hit the hop add time it sends info to terminal and a notification.
Here is how I initialize the arrays holding the hop add time, and the information that is diaplyed in the terminal. I initialize a 20 sized array becuase there are usually not more that 4/5 hop adds, so then using the terminal widget I modify the first few indexes of those arrays:
    int hopCounter; //Number of hop adds that I input, based upon my terminal input
    int HopAddtime;
    int HOPTIME[20]; // Hop times
    String HOPINFO[20];  // HOPINFO;
Next is how I input the data to modify HOPTIME and HOPINFO arrays. I use the first letter T or I to decide which array to modify, then using comma delimited type I add in what should be in each index of the array. This step seems to work as the output to terminal confirms my entries.
BLYNK_WRITE(V14)  // Terminal for HOPTIME and HOPINFO input
  String fromTerminal = param.asStr();
  if (fromTerminal.endsWith("?")) {
   terminalHops.println("Comma delimited, and first letter followed by '!' resets previous inputs: HOPTIMES:start w/ 'T,'//HOPINFO: starts w/ 'I,'");
   terminalHops.flush();
  if (fromTerminal.startsWith("T") ) { //Hoptimes input
      int lastIndex;
      if (fromTerminal.endsWith("!")){ //In case I need to reset everything and re input hop additions
       hopCounter = 0;
       lastIndex = 0;
      fromTerminal.remove(0,1);
      for (int i = 0; i < fromTerminal.length(); i++) {
        if (fromTerminal.substring(i, i+1) == ",") {
          HOPTIME[hopCounter] = (fromTerminal.substring(lastIndex, i)).toInt();
          lastIndex = i + 1;
          hopCounter++;
        if (i == fromTerminal.length() - 1) {  // If we're at the end of the string (no more commas to stop us)
      terminalHops.print(HOPTIME[1]);
      terminalHops.print(" from ArrayHOPTIME ");
      terminalHops.print(hopCounter);
      terminalHops.println(" total inputs");
  if (fromTerminal.startsWith("I")){ //Hopinfo input
      int counter;
      int lastIndex;
       counter = 0;
       lastIndex = 0;
          HOPINFO[counter] = fromTerminal.substring(lastIndex, i);
          lastIndex = i + 1;
          counter++;
      terminalHops.print(HOPINFO[1]);
      terminalHops.print(" from CharArrayHOPINFO ");
      terminalHops.print(counter);
This next part is where I get the disconnection error. This is during the boil phase, it should access the HOPINFO and HOPTIME arrays and then display what hops I need to add when the hop time is up. However every time my code switches to the boil phase, there are lines of “Add:” that display on the terminal and then the Wemos disconnects.
//Hop Additions Code
case 9:
  switchState =0;
  for (int h=0 ; h=hopCounter; h++) {
       HopAddtime = HOPTIME[h];
       if (ElapsedBoilTime >= (HopAddtime - 1.0) && ElapsedBoilTime <= (HopAddtime + 1.0)) { //BE SURE THAT THE +/- of the elapsedboil time doesnt result in overlay of two hop additions or else it could be confusing
        tone(BUZZER,500,2000);
        terminal.print("Add: ");
        terminal.println(HOPINFO[h]);
        terminal.flush();
        Blynk.notify(HOPINFO[h]);
break;
Below is my full code for reference:
////Sensor Initialization, DO NOT CHANGE
#include <OneWire.h>
#include <Wire.h>
#define ONE_WIRE_BUS D1 //Sensor location
DallasTemperature sensor(&oneWire);
//////////////////////BLYNK CODE
//#define BLYNK_PRINT Serial
const char* ssid = "NETGEAR20";
const char* password = "bluelotus378";
char auth[] = "6e413df8de034a9e86a5604d3d2a91ab";
WidgetTerminal terminal(V0);
WidgetTerminal terminalHops(V14);
////////Setting up variables to be declared by Blynk app
int MASHTEMP; // Desired Mash Temp(deg F)
int MASHTIME; //Desired Mash Time(milli sec.)
int BOILTIME; //Desired Boil Time(milli sec.)
int CHILLTIME; //Desired time to pump all wort through the wort chiller (milli sec.)
int HopAddtime;
////////////Assign counters for independent and pause control buttons
int noButtonCounter;
int pacounter;
int pucounter;
int h1counter;
int h2counter;
////////////////////////Assign variables
float tanktemp; //Declaring temperature variables
unsigned long btstart;
unsigned long btstart1;
unsigned long btstart2;
unsigned long pausestart; //Time when pause button was pushed
unsigned long elapsedpausetime;
unsigned long elapsedpumptime;
unsigned long elapsedh1time;
unsigned long elapsedh2time;
unsigned long totalpausem;
unsigned long totalpauseb;
unsigned long totalpausec;
unsigned long startingtime; //overall starting time
unsigned long ElapsedPreMashTime;
unsigned long MashStartTime; //used for MASH TIME
unsigned long ElapsedMashTime;
unsigned long BoilStartTime; //used for BOIL TIME
unsigned long ElapsedBoilTime;
unsigned long ChillStartTime; //used for BOIL TIME
unsigned long ElapsedChillTime;
//Setup all states
int switchState;
boolean autostart = true;
boolean premash;
boolean mashPID;
boolean reheatpremash;
boolean mashrun;
boolean mashreheat;
boolean mashend;
boolean boilrun;
boolean reboil;
boolean boilend;
boolean chillrun;
boolean rechill;
boolean chillend;
//Pin Inputs/Outputs to Arduino:
const int BUZZER = D0;
const int HEATER1 = D5;
const int HEATER2 = D6;
const int PUMP = D7;
//Status variables for buttons
int val_start;
int val_pause;
int val_pump;
int val_heater1;
int val_heater2;
void brewingstuff(){
//No button pressed nothing is on (Also works so that when Auto button is on and then turned off, everything shuts down
if (val_start == LOW && val_pause == LOW && val_pump == LOW && val_heater1 == LOW && val_heater2 == LOW){
      switch (noButtonCounter){
      case 0:
         digitalWrite(HEATER1, LOW);
         digitalWrite(HEATER2, LOW);
         digitalWrite(PUMP, LOW);
         terminal.println("No Button Pressed, to pause must press pause button!");
         terminal.flush();
         noButtonCounter = 1;
         pausestart = (millis()/60000);
      break;
      case 1:
       elapsedpausetime = ((millis()/60000) - pausestart);
       terminal.print("No button pressed for:  ");
       terminal.println(elapsedpausetime);
       terminal.flush();
      break;}
//If anything is pressed right after no button was pressed, reset no button counter, set re heat states if needed, and increase "pause" time
if ((val_start == HIGH || val_pause == HIGH || val_pump == HIGH || val_heater1 == HIGH || val_heater2 == HIGH) && noButtonCounter == 1){
        noButtonCounter = 0;
        if (premash == true){
          reheatpremash = true;
        else if (mashrun == true){
          totalpausem = totalpausem + elapsedpausetime;
          terminal.print("Time Added to Mash: ");
       else if (boilrun == true){
          reboil = true;
          totalpauseb = totalpauseb + elapsedpausetime;
          terminal.print("Time Added to Boil: ");
       else if (chillrun == true){
          rechill = true;
          totalpausec = totalpausec + elapsedpausetime;
          terminal.print("Time Added to Chill: ");
   elapsedpausetime=0;
//pause stops everything
if (val_pause == HIGH){
       switch (pacounter){
       case 0:
        Blynk.virtualWrite(V4,LOW);
        Blynk.virtualWrite(V6,LOW);
        Blynk.virtualWrite(V7,LOW);
        Blynk.virtualWrite(V8,LOW);
        val_start=LOW;
        val_pump=LOW;
        val_heater1=LOW;
        val_heater2=LOW;
        pucounter=0;
        h1counter=0;
        h2counter=0;
        pausestart=(millis()/60000);
        pacounter=1;
        terminal.println("PAUSE WORKING");
      break;
      case 1:
       terminal.print("Manual Pause for: ");
       terminal.flush();
      break;}
///Pause button on and then turned off it resets counter, re heats if needed, and increased pause time
if (pacounter == 1 && val_pause == LOW){
       pacounter = 0;
          reboil = true;
          rechill = true;
     elapsedpausetime=0;
//Button pressed on pump starts
if (val_start == LOW && val_pause == LOW && val_pump == HIGH){
      switch (pucounter){
       case 0:
        terminal.println("Pump starting, need to open ball valve!!");
        terminal.flush();
        tone(BUZZER,500,5000);
        digitalWrite(PUMP, HIGH);
        btstart=(millis()/60000);
        pucounter=1;
       break;
       case 1:
        elapsedpumptime = ((millis()/60000) - btstart);
        terminal.print("Manual Pump On for: ");
        terminal.println(elapsedpumptime);
        terminal.flush();
       break;
///Pump button on and then turned off it stops pump
if (pucounter == 1 && val_pump == LOW){
    pucounter = 0;
          totalpausem = totalpausem + elapsedpumptime;
          reboil = true;
          totalpauseb = totalpauseb + elapsedpumptime;
          rechill = true;
          totalpausec = totalpausec + elapsedpumptime;
    elapsedpumptime = 0;
//Heater 1 button pressed on heater starts
if (val_start == LOW && val_pause == LOW && val_heater1 == HIGH){
      switch (h1counter) {
      case 0:
        btstart1=(millis()/60000);
        terminal.println("Heat 1 starting, need cover w water!!");
        terminal.flush();
        digitalWrite(HEATER1, HIGH);
        h1counter=1;
      break;
      case 1:
       elapsedh1time = ((millis()/60000) - btstart1);
       terminal.print("Manual Heater 1 On for: ");
       terminal.println(elapsedh1time);
       terminal.flush();
      break; }
///When Heater1 button on and then turned off it stops one heater
if (h1counter == 1 && val_heater1 == LOW){
        h1counter = 0;
          totalpausem = totalpausem + elapsedh1time;
          reboil = true;
          totalpauseb = totalpauseb + elapsedh1time;
          rechill = true;
          totalpausec = totalpausec + elapsedh1time;
    elapsedh1time=0;
if (val_start == LOW && val_pause == LOW && val_heater2 == HIGH){
      switch (h2counter){
      case 0:
        btstart2=(millis()/60000);
        terminal.println("Heat 2 starting, need cover w water!!");
        terminal.flush();
        digitalWrite(HEATER2, HIGH);
        h2counter=1;
      break;
      case 1:
       elapsedh2time = ((millis()/60000) - btstart2);
       terminal.print("Manual Heater 2 On for: ");
       terminal.println(elapsedh2time);
       terminal.flush();
      break;}
///When Heater2 button on and then turned off it stops two heater
if (h2counter == 1 && val_heater2 == LOW){
        h2counter = 0;
          totalpausem = totalpausem + elapsedh2time;
          reboil = true;
          totalpauseb = totalpauseb + elapsedh2time;
          rechill = true;
          totalpausec = totalpausec + elapsedh2time;
    elapsedh2time=0;
//Auto Brewing State decision upfront
ElapsedPreMashTime = (millis()/60000) - startingtime;
ElapsedMashTime = (millis()/60000) - MashStartTime - totalpausem;
ElapsedBoilTime = (millis()/60000) - BoilStartTime - totalpauseb;
ElapsedChillTime = (millis()/60000) - ChillStartTime - totalpausec;
if (tanktemp < MASHTEMP && autostart == true && switchState ==0) {
  switchState=1;
else if (tanktemp >= MASHTEMP - 5.0 && tanktemp < MASHTEMP - 2.0 && premash == true && mashPID == false && switchState ==0) {
  switchState=2;
else if (tanktemp >= MASHTEMP - 2.0 && tanktemp <= MASHTEMP + 2.0 && premash == true && switchState ==0) {
  switchState=3;
else if (tanktemp <= MASHTEMP - 8.0 && mashrun == true && mashreheat == false && switchState ==0){
  switchState=4;
else if (tanktemp >= MASHTEMP && mashreheat == true && switchState ==0){
  switchState=5;
else if (ElapsedMashTime >= MASHTIME && mashrun == true && switchState ==0) {
  switchState=6;
else if (tanktemp >= 200 && mashend == true && switchState ==0) {
  switchState=7;
else if (reboil == true && switchState ==0){
  switchState=8;
else if (ElapsedBoilTime < BOILTIME + 1 && boilrun == true && switchState ==0) {
  switchState=9;
  if (ElapsedBoilTime >= BOILTIME - 8 && ElapsedBoilTime <= BOILTIME - 7){
    terminal.println("Boil Almost Done: Add Immersion Chiller & begin yeast starter");
    terminal.flush();
else if (ElapsedBoilTime >= BOILTIME && boilrun == true && switchState ==0) {
  switchState=10;
else if (tanktemp <= 190 && boilend == true && switchState ==0) {
  switchState=11;
else if (rechill == true && switchState ==0){
  switchState=12;
else if (ElapsedChillTime >= CHILLTIME && chillrun == true && switchState ==0) {
  switchState=13;
else if (reheatpremash == true && switchState ==0) {
  switchState=14;
//When Auto Brewing Start button pressed
if (val_start == HIGH && val_pause == LOW && val_pump == LOW && val_heater1 == LOW && val_heater2 == LOW){
switch (switchState){
//premash = Heater 1 & 2 on, pump off
case 1:
      switchState = 0;
      startingtime = (millis()/60000);
      terminal.println(startingtime);
      premash=true;
      autostart = false;
      terminal.println("Heat starting, need to cover with water!!");
      terminal.flush();
      terminal.println("Heaters On");
      terminal.flush();
break;
//reheatpremash: turn heaters back on after a pause during premash stage
case 14:
    switchState = 0;
    reheatpremash = false;
    terminal.println("Back from pause, premash heaters back on");
    terminal.flush();
break;
//close to mash temp = only one heater stay on (MY VERSION OF A PID)
case 2:
    Blynk.notify("Close to MashTemp, ready to insert grain");
    switchState = 0;
    mashPID = true;
    terminal.println("Temp close to Mash, one heater on");
    terminal.flush();
break;
//mashrun = heaters off, pump on
case 3:
    switchState = 0;
    mashrun = true;
    premash=false;
    MashStartTime = (millis()/60000);
    terminal.println("Mash temp hit, mash begin");
    terminal.flush();
break;
//Mash Reheat Adds function so that if paused or a lot of heat loss the heater keeps us at mash temp
case 4:
  switchState = 0;
  mashreheat = true;
  terminal.println("Heat loss, heaters back on");
  terminal.flush();
break;
//Mash Reheat Complete
case 5:
  switchState = 0;
  mashreheat = false;
  terminal.println("Mash back up to temp, heaters back off");
  terminal.flush();
break;
//mashend = heaters both on, pump off
case 6:
    switchState = 0;
    mashend = true;
    mashrun = false;
    terminal.println("Mash Complete, heat on, pump off, pre boil stage");
    Blynk.notify("REMOVE GRAIN BAG: Mash Complete, heat on, pump off, pre boil stage");
    terminal.flush();
break;
//boilrun
case 7:
    switchState = 0;
    boilrun = true;
    mashend= false;
    BoilStartTime = (millis()/60000);
    terminal.println("Boiling start, heaters on, pump off, look for hop adds");
    terminal.flush();
break;
//reboil: turn heaters back on after a pause during boilrun stage
case 8:
    switchState = 0;
    reboil = false;
    terminal.println("Back from pause, boil started again");
    terminal.flush();
break;
case 9:
  switchState =0;
        terminal.flush();
break;
//boilend = heat off , pump off
case 10:
    switchState = 0;
    boilend = true;
    boilrun = false;
    terminal.println("Boil Complete");
    Blynk.notify("INSERT IMMERSION CHILLER IMMEDIATELY, CONNECT ALL CHILL TUBING, MAKE SURE FERMENTER IS READY:Boil Complete");
    terminal.flush();
break;
//chill run: Turns pump on once temp is low enough that going through plate chiller will work: Maybe bump up this temperature
case 11:
    switchState = 0;
    chillrun = true;
    boilend = false;
    ChillStartTime = (millis()/60000);
    terminal.flush();
break;
//rechill: turn pump back on after a pause during chillrun stage
case 12:
    switchState = 0;
    rechill = false;
    terminal.println("Back from pause, chill pumping started again");
    terminal.flush();
break;
//chillend == turn pump off once estimated chill time is over
case 13:
    switchState = 0;
    chillend = true;
    chillrun = false;
    terminal.println("Auto Brewing Complete");
    Blynk.notify("Auto Brewing Complete");
    terminal.flush();
break;
/////////BLYNK CODE: DISPLAYS AND INPUTS
///////BLYNK DASHBOARD DISPLAYS
//Send tanktemp continuously
BLYNK_READ (V9)
  Blynk.virtualWrite(V9,tanktemp);
//Send Elapsed Time to BLYNK Dashboard Display
BLYNK_READ(V11)
    Blynk.virtualWrite(V11, ElapsedPreMashTime);
    Blynk.virtualWrite(V11, ElapsedMashTime);
    Blynk.virtualWrite(V11, ElapsedBoilTime);
    Blynk.virtualWrite(V11, ElapsedChillTime);
    Blynk.virtualWrite(V11, 0);
//Display Phase which corresponds with the elapsed time above
BLYNK_READ(V10)
    Blynk.virtualWrite(V10, "preM");}
    Blynk.virtualWrite(V10, "MASH");}
  else if (mashend == true){
    Blynk.virtualWrite(V10, "preB");}
  else if (boilrun == true) {
    Blynk.virtualWrite(V10, "BOIL");}
    Blynk.virtualWrite(V10, "CHILL");}
  else {
    Blynk.virtualWrite(V10, "N/A");}
//////////////////////USER INPUTS: Mash Time, Mash Temp, Boil Time, Chill Time, Hop Times, Hop Info, Manual State Change
BLYNK_WRITE(V15)
  switch (param.asInt()){
       case 1 :
        terminal.println("Variables Reset");
        terminal.flush();
        autostart = false;
        premash = false;
        mashPID = false;
        mashrun = false;
        mashreheat = false;
        mashend = false;
        boilrun = false;
        reboil = false;
        boilend = false;
        chillrun = false;
        rechill = false;
        chillend = false;
        terminal.println("Reverted Back to Pre-Mash Stage");
        terminal.flush();
        switchState = 1;
        break;
       case 2 :
        terminal.flush();
        autostart = false;
        premash = false;
        mashPID = false;
        mashrun = false;
        mashreheat = false;
        mashend = false;
        boilrun = false;
        reboil = false;
        boilend = false;
        chillrun = false;
        rechill = false;
        chillend = false;
        terminal.println("Reverted Back to Mash Stage");
        terminal.flush();
        switchState = 3;
        break;
       case 3 :
        terminal.flush();
        autostart = false;
        premash = false;
        mashPID = false;
        mashrun = false;
        mashreheat = false;
        mashend = false;
        boilrun = false;
        reboil = false;
        boilend = false;
        chillrun = false;
        rechill = false;
        chillend = false;
        terminal.println("Reverted back to Boil Stage");
        terminal.flush();
        switchState = 6;
        break;
BLYNK_WRITE(V1)
  MASHTEMP= param.asInt();
  terminalHops.print("MASHTEMP SET AS: ");
  terminalHops.println(MASHTEMP);
BLYNK_WRITE(V2)
  MASHTIME= param.asInt();
  terminalHops.print("MASHTIME SET AS: ");
  terminalHops.println(MASHTIME);
BLYNK_WRITE(V3)
  BOILTIME= param.asInt();
  terminalHops.print("BOILTIME SET AS: ");
  terminalHops.println(BOILTIME);
BLYNK_WRITE(V13)
  CHILLTIME= param.asInt();
  terminalHops.print("CHILLTIME SET AS: ");
  terminalHops.println(CHILLTIME);
      int lastIndex;
       hopCounter = 0;
       lastIndex = 0;
          lastIndex = i + 1;
          hopCounter++;
      int counter;
      int lastIndex;
       counter = 0;
       lastIndex = 0;
          lastIndex = i + 1;
          counter++;
////Manual Controls
BLYNK_WRITE(V4) //Start Button
  val_start= param.asInt();
BLYNK_WRITE(V5) //Pause Button
  val_pause= param.asInt();
BLYNK_WRITE(V6) //Pump Button
  val_pump= param.asInt();
BLYNK_WRITE(V7) //Heater 1 Button
  val_heater1= param.asInt();
BLYNK_WRITE(V8) //Heater 2 Button
  val_heater2= param.asInt();
  Blynk.begin(auth,ssid,password);
  timer.setInterval(1000, brewingstuff); //Check my brewing code every 1s
  sensor.begin();
  sensor.setResolution(9); //Resolution of 9 means 0.5degC increments.
  pinMode(PUMP, OUTPUT); //initialize pin locations as output or input
  pinMode(HEATER1, OUTPUT);
  pinMode(HEATER2, OUTPUT);
  pinMode(BUZZER, OUTPUT);
  terminal.println("Setup done, Phil's beer is on the way, Ready?");
  terminal.flush();
  sensor.requestTemperatures(); //Get TEMP reading continuously
  tanktemp = sensor.getTempFByIndex(0);
Have you solved your problem? I think i meet the problem too. When i trying to get a function that containing the millis(), the blynk apps will shows “Device was disconnected” and cannot even perform normal control LED. But what using esp8266 standalone example, it works fine.
I have not had extensive testing; but I tried to run the ESP board via a battery instead of plugging into a wall outlet and I did not have random disconnections.
This led me to believe perhaps it was power getting to the ESP board that was the issue for me. But I want to test it again several more times to confirm this.
As far as the millis() function I have used that a lot and not had issues so not sure the problem there. Sorry.
That is because your loop() is not even close to being acceptable.
