Code analog read A0 with arduino yun
Before creating the topic
  1. Search forum for similar topics
  2. Check http://docs.blynk.cc and http://help.blynk.cc/
  3. Add details :
    • Blynk Library version
    • Add your sketch code. :point_up:Code should be formatted as example below.
Great, you’ve learned how to copy/paste… :smiley:
Is there a question you want to ask also? :thinking:
Actually, not even that :joy: This text is automatically generated upon help topic creation.
I suspect the question/issue lies in the title… so an equally obscure answer should suffice…
int value = analogRead(A0);
ik wil gewoon een simpele code om een analoge ingang te meten zonder virtuele pinnen . Kan ik een code krijgen voor mijn arduino yun visueel met blynk
Sure… run this and hook up a Gauge widget to Analog A0… Then after a few hours when you are bored with the limited direct pin controls, you can learn how to do more with Virtual Pins and coding :stuck_out_tongue_winking_eye:
#include <Bridge.h>
#include <BlynkSimpleYun.h>
Blynk_READ5(V5)
sensorData = analogRead(A0);
Blynk.virtualWrite ( V5,sensordata);
// initialize serial communication at 9600 bits per second:
// the loop routine runs over and over again forever:
// read the input on analog pin 0:
int sensorValue = analogRead(A0);
// Convert the analog reading (which goes from 0 - 1023) to a voltage (0 - 5V):
float voltage = sensorValue * (5.0 / 1023.0);
// print out the value you read:
Serial.println(voltage);
Aside from syntax errors in your code… it is not properly formatted here for forum viewing…
Blynk%20-%20FTFC
