Co2 sensor:MH-Z19, Blynk, ESP
Hi i have CO2 sensor:,mh-z19. I need sending data to app Blynk. But this sketch no working.?
And sketch for thingspek from: https://github.com/asvavilov/iot-climate is working good.
Thanks.
#include <Wire.h>
#include <SoftwareSerial.h>;
// MH-Z19:
// power - 5v
// D6 - TX sensor, D7 - RX sensor
#define CO2_TX D6
#define CO2_RX D7
SoftwareSerial co2Serial(CO2_TX, CO2_RX);
char auth[] = "";  // Put your Auth Token here. (see Step 3 above)
   Blynk.begin(auth, "", ""); //insert here your SSID and password
  timer.setInterval(10000L, sendUptime);
  co2Serial.begin(9600);
  co2Serial.flush();
int readCO2()
  byte cmd[9] = {0xFF, 0x01, 0x86, 0x00, 0x00, 0x00, 0x00, 0x00, 0x79};
  char response[9];
  co2Serial.write(cmd, 9); //request PPM CO2
  co2Serial.readBytes(response, 9);
  byte crc = 0;
  for (int i = 1; i < 8; i++)
    crc += response[i];
  crc = 255 - crc;
  crc++;
  if (response[8] != crc)
    Serial.println("Wrong crc from co2 sensor!");
    return -1;
  if (response[0] != 0xFF)
    Serial.println("Wrong starting byte from co2 sensor!");
    return -1;
  if (response[1] != 0x86)
    Serial.println("Wrong command from co2 sensor!");
    return -1;
  int responseHigh = (int) response[2];
  int responseLow = (int) response[3];
  int ppm = (256 * responseHigh) + responseLow;
  return ppm;
void sendUptime()
  float co2_ppm = co2Serial.readCO2();
  Blynk.virtualWrite(1, co2_ppm); // virtual pin
error:
blynk_co2.ino: In function 'void sendUptime()':
blynk_co2:80: error: 'class SoftwareSerial' has no member named 'readCO2'
blynk_co2:82: error: 'ppm' was not declared in this scope
@Jiri_Bam in the original sketch it includes this line:
int co2_ppm = readCO2();
You decided to change it to this buggy line:
Change it back and the code will compile.
For reference the original sketch and yours also have:
include statements are not terminated with ; but most compilers will handle it. Remove the ;
So YES now is sketch working. And SoftwareSerial i no remove.
But in blynk is CO2 exploring: 998.0000 i want 998 without .0000
THanks.
#include <Wire.h>
// MH-Z19:
// power - 5v
#define CO2_TX D6
#define CO2_RX D7
  co2Serial.flush();
int readCO2()
  char response[9];
  byte crc = 0;
    crc += response[i];
  crc = 255 - crc;
  crc++;
    return -1;
    return -1;
    return -1;
  return ppm;
void sendUptime()
  float co2_ppm = readCO2();
Spend a few days reading the docs and it will all become clear to you.
I dont know but in Gauge it is good: 998. And in Labeled Value are exploring 998.0000…
Thanks.
Because you declare it as float.
Change to int
