Hi to all. I’am experiencing a strange problem with my sketch and i need your help.
I want to add a i2c lcd diplay to my project but when I simply add Wire.h the connection with blynk fail with “Cmd error”
I searched in the forum but i didn’t find an answer to my problem.
Can someone help me ?
http://twitter.com/blynk_app
WARNING!
It's rather tricky to get it working, please read this article:
https://github.com/blynkkk/blynk-library/wiki/ESP8266-with-AT-firmware
You’ll need:
- Blynk App (download from AppStore or Google Play)
- Arduino Uno board
example.
#define BLYNK_DEBUG
#define BLYNK_GREEN "#23C48E"
#define BLYNK_BLUE "#04C0F8"
#define BLYNK_YELLOW "#ED9D00"
#define BLYNK_RED "#D3435C"
#define BLYNK_DARK_BLUE "#5F7CD8"
#define DHTPIN 7 // what digital pin we're connected to
#include <Wire.h>
//#include <LiquidCrystal_I2C.h>
#include <ESP8266_Lib.h>
#include <PID_v1.h>
#include <CountUpDownTimer.h>
char auth[] = "a77277448436405aa115303ec2ab1883";
char ssid[] = "protected";
char pass[] = "nintendo";
//#define EspSerial Serial1
#include "DHT.h" // Including library for dht
SoftwareSerial EspSerial(9, 10); // RX, TX
// Your ESP8266 baud rate:
#define ESP8266_BAUD 115200
ESP8266 wifi(&EspSerial);
//Specify the links and initial tuning parameters
double Kp = 10, Ki = 1, Kd = 1;
//Define Variables we'll be connecting to
double Setpoint, Input, Output;
double Humidity, Temperature;
int humSetpoint;
DHT dht(DHTPIN, DHTTYPE);
PID myPID(&Temperature, &Output, &Setpoint, Kp, Ki, Kd, AUTOMATIC);
//Timer management
CountUpDownTimer T(DOWN, LOW);
unsigned long Timer_Duration = 1200 ;//43200; // runtime in seconds
//LiquidCrystal_I2C lcd(0x27, 20, 4); // set the LCD address to 0x27 for a 16 chars and 2 line disp
// Set ESP8266 baud rate
EspSerial.begin(57600);
EspSerial.write ("AT+UART=9600,8,1,0,0\r\n");
EspSerial.begin(9600);
//Blynk.begin(auth, wifi, ssid, pass, "blynk-cloud.com", 8442);
//Blynk.begin(auth, wifi, ssid, pass, IPAddress(192,168,1,100), 8442);
timer.setInterval(1000L, ReadAndCompute);
T.SetTimer( Timer_Duration);
T.StartTimer();
// lcd.init(); // initialize the lcd
// lcd.backlight();
// to avoid delay() function!
BLYNK_CONNECTED() {
Blynk.virtualWrite(V0, 28);
Blynk.virtualWrite(V1, 75);
Blynk.virtualWrite(V11, (int)Kp);
Blynk.virtualWrite(V12, (int)Ki);
Blynk.virtualWrite(V13, (int)Kd);
// Blynk.virtualWrite(V7, (double)Timer_Duration / 60);
Blynk.setProperty(V9, F("color"), BLYNK_GREEN );
// Blynk.virtualWrite(V9, 0);
// UpdateTimer();
void ReadAndCompute()
Humidity = dht.readHumidity();
Temperature = dht.readTemperature();
//Serial.println(T.ShowTotalSeconds() );
//Serial.println(Timer_Duration);
myPID.Compute();
