Hi Guys,
Have a weird issue, if I attempt to read and ADS1115 on the I2C bus and then pump the information up using Blynk using virtualwrite to a V## process to start sending the information up doesnt work. This only occurs if I use Blynk Timer and the recommended way of calling all functions with timers.
Core below that causes the issue:
#define BLYNK_DEBUG
#include <ESP8266_Lib.h>
#include <Adafruit_ADS1015.h>
char auth[] = "***";
char ssid[] = "***";
char pass[] = "***";
#define ESP8266_BAUD 9600
ESP8266 wifi(&EspSerial);
Adafruit_ADS1115 adsA(0x48); /* Use this for the 16-bit version */
delay(100);
adsA.setGain(GAIN_ONE); // 1x gain +/- 4.096V 1 bit = 2mV 0.125mV
adsA.begin();
delay(100);
timer.setInterval(1000L, countuptime);
timer.setInterval(2000L, systemvoltage);
timer.run(); // BlynkTimer is working...
void systemvoltage()
// IF I COMMENT OUT ALL OF THE BELOW IN THIS FUNCTION THE CODE RUNS.
Serial.println("System Voltage (RAW): ");
int16_t adcA0;
adcA0 = adsA.readADC_SingleEnded(1);
Serial.println(adcA0);
Blynk.virtualWrite(V13, adcA0);
void countuptime()
Serial.println("System Uptime Function: +1");
Blynk.virtualWrite(V12, millis() / 1000);
Blynk debug shows the following error:
[22318] <[11|00|02|00]gver[00]0.6.1[00]h-beat[00]10[00]buff-in[00]256[00]dev
[32429] Cmd error
[42877] <[1D|00|01|00] my blynk auth key is repeated here
[53619] <[1D|00|01|00] my blynk auth key is repeated here
[64445] <[1D|00|01|00] my blynk auth key is repeated here
The ADS115 unit works as it should standalone, I2C scanner reads successfully and also ADC reads are good too.
Also, if I move the below into VOID LOOP and remove all TIMER code it works and info is uploaded into server/app/widget. But this isnt recommend and the use of timers is best practice, which is what I want to acheive.
int16_t adcA0;
Iβm assuming there might be some conflict between the ADS library and Blynk timer (which is an adopted Simplertimer varient/tweaks.
Any help would be muchly appreciated.
Cheers,
