[CLOSED] Decimal point/thousands separator
I have noticed that the decimal separator and the thousands separator are both points which I think is confusing especially in countries where a comma is used for the decimal point.
Are there any plans to change that?
Here is a list which shows the countries using a dot and the countries using a comma:
https://en.wikipedia.org/wiki/Decimal_mark
Kind regards,
Tom
Not a Blynk issue…this is a C++ issue.
A simple Google search helps: https://www.google.co.nz/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=changing%20decimal%20mark%20in%20c%2B%2B
Thanks for your answer, I did not know that. But there seem to be also different solutions to deal with this issue in C++
Maybe the Blynk Team can implement that?
Again, not a Blynk issue and you need to write the fix in to your own code.
