Checking if arduino is connected if not restart
Hi, i am having a problem with my Ethernet shield not working after a couple of hours, so my solution is, when the arduino is not connected to the blynk server activate pin 4 which triggers relay tieing ground to reset then turning off pin 4.
    Social networks:            http://www.fb.com/blynkapp
                                http://twitter.com/blynk_app
  This example shows how to use Arduino Ethernet shield (W5100)
  to connect your project to Blynk.
  NOTE: Pins 10, 11, 12 and 13 are reserved for Ethernet module.
        DON'T use them in your sketch directly!
  WARNING: If you have an SD card, you may need to disable it
        by setting pin 4 to HIGH. Read more here:
        https://www.arduino.cc/en/Main/ArduinoEthernetShield
#include <Ethernet.h>
#define W5100_CS  10
#define SDCARD_CS 4
bool result;
  result = false;
  pinMode(3, OUTPUT);
  digitalWrite(3, LOW);
  pinMode(SDCARD_CS, OUTPUT);
  digitalWrite(SDCARD_CS, HIGH); // Deselect the SD card
  Blynk.begin(auth);
  //Blynk.begin(auth, "blynk-cloud.com", 80);
  //Blynk.begin(auth, IPAddress(192,168,1,100), 8080);
  // For more options, see Boards_Ethernet/Arduino_Ethernet_Manual example
  bool result = Blynk.connected();
  delay(500);
  if (result = true);
      // engage reset function
      digitalWrite(3, HIGH);
      delay(500);
      digitalWrite(3,LOW);
Well, you do not need that last part, since after the reset… well… no more code running :stuck_out_tongue:
Other than that… is there a question about an issue?
BTW, there are simpler ways to do this without a relay…
