Changing Hardware without loosing Widgets
I need to change my Hardware Board setting in the in the App but he tells me all my Widgets will get reset.
I don’t want to recreate 3 entire screens of Widgets with a huge amount of individual settings each.
So how can I do this without manually redo the entire 3 Screens?
Hi Gorkde
Widgets would not be removed, but their pins (except virtual ones) would be erased - so you should re-setup pins for your widgets after hardware model change.
So settings like Push time etc will stay?
pins and min/max values for analog/pwm pins as they could differ across various hardware
